ok im not sure whats going on, or is it the fact that my car is an auto or what. i had like 6 tunes including the stock tune, and still i cant ever do a burn out, my 0-60mph is still any where from 9 to 10.5 seconds (wich is extreamly slow) and i was playing around with the tourque reduction in my tranny and in my engine and it didnt change any thing, 0-60 times were still the same. im not getting it what so ever, not sure if theres a problem or whats going on. and with the mods i have it should be alot better than it is.
wierd........ but if you gys have any idea on what is going on please help
car: 2002 camaro
engine:3800 series II
transmission: 4L60E
rearend gears: 3.42
weight of car: not sure but guestimating around 3600 lbs
mods to engine: HPTuners tune, full exhaust headers on back, full msd ignition, Bosh +4 iridium plugs, custome air intake with ram air(SLP intake), throttle body spacer, 160* thermostat, dexcool anti freez with royal purple aditive, K&N oil and air filter, PLX Devices wide band 02 sensor, royal purple oil.
soon to come:comp cams roller lifters, manley push rods, comp cams custome grind cam
cam specs: Duration (Intake/Exhaust): 210°/220° @ .050"
Valve Lift (w/1.66 Rocker): .533"/.544"
Lobe Sep. Angle: 113°
hoping the cam will wake my car up
