Results 1 to 5 of 5
Thread: select Vehicles?
    May 2004
    FWB Fl
    299
    select Vehicles?
    is there a way to select the Vehicles if your HPT has been hooked up to a bunch?
    the time i used it was hooked up to my truck now i need to adjust my scanner and my car is down so i can't hook it up to my car to get its parameters
    also is there a way to transfer that to my desk top? (witch is what i use to tune most of the time becuase the screen is bigger)
    http://www.turbov6camaro.com
    1997 Stalled V6 Camaro
    Goal: 10.99 in the 1/4
    Goal: 100 MPH (completed)
    Best Dyno: 456 RWHP and 509 RWTQ
    Best: 1/4 mile 11.23 20 PSI
    Best1/8: 7.18 @ 99 1.83, 60 foot 20 PSI
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,290
    You can modify the VCM Scanner.cfg file but the parameter list will likely be inaccurate until you actually connect to the vehicle.
    May 2004
    FWB Fl
    299
    so there no way to get my dest top right with out getting it very close to the car?
    HP Tuners Support
    (foff667)
    28,290
    Yup. It will be close but might not be exact until you actually poll the vehicle.
    May 2004
    FWB Fl
    299
    what about my lap that has already been connectec to the car?
    EG was on car
    moved to truck to scan codes
    can't move back to car becuase its down.....
    i see the the file for the car under the vehicels folder but i can't get it to use it
    so if i change it like you say will i still need to connect it? or does it make a new file everytime you connect to the car
