Hey, I have a question for you. I used your trans diag. config you attatched in this thread: http://www.hptuners.com/forum/showthread.php?t=20044 .
Now, when i use your trans config( http://www.hptuners.com/forum/showthread.php?t=20044 ), the speedo stays at 0mph. but when i goto use default config, it works fine.
now, the trans is locked in first gear, as though no other gears work. more than likely a rebuild is here, but i'm wondering if there's any way it can be a tuning issue? It was a stock trans with stock verter. (this is my 98 Z28, not my 98 turbo ws6)
manual shifting doesn't go into other gears either. reverse, neutral, first gear, etc.. work fine. whe manual shifting or evne fully auto "D", just bounces off rev limiter. fluid levels are fine, nothing smells or looks burnt.
