i have a 2000 camaro with a midsized cam and bolt-ons. with the stock injectors (26.6lbs) and a walbro 255 pump my car was at 98% duty cycle. that fuel pump died in under a year and i ran the car not knowing it with very low fuel pressure, the injector duty cycle was at 120% so i installed a racetronixs 255 and a hot wire kit at 65psi. the injector duty cycle was still at 110%. i replaced my injectors with some out of a low milage 02 ws6(28.8lbs) and my injector duty cycle is still around 105%. through all of this i never messed with the tune except to change the injector flow rate to match a stock 02 ls1 car. why is my duty cycle so high?? i have seen several heads and cam cars run 28lbs injectors and they should be plenty for my car.
when data logging a run of my car my VE tables show 0 from 4000rpm and up so the air fuel should be close shouldn't it? and is this effecting the way my car pulls on the top end?
please help have a race coming soon!!
my cam is a 228/232 588/595 and i have basic bolt-ons and at the time of the tune my air/fuel was around 13.0 and 12.9
