Hi, this is a question for HP Tuners since they're familiar with the OS portion of the PCM code and what basis some decisions are made on...
If I look at the V8's, There is a PE Enable %TPS vs RPM (Hot) table, a PE Enable %TPS vs RPM (Cold) table, and a Hot Select temp that is used as a switch to select the appropriate table in use. The V6's on the other hand only have one, the PE Enable %TPS vs RPM (Hot) table. There is no cold table shown, and also no select temp. From this I see two possibilities:
1) Like the V8's, the V6's have the same two tables and select temp, but HP Tuners have not yet located the cold table or the select temp. Or,
2) The V6's only have one table (and therefore do not need a select temp), but the button shown in the Power Enrich tab is merely recycling the "Hot" label from the V8 screen display.
Which is it? I'd like to start playing with the data in there.
TIA,
John
