Well, I have 2010 Camaro SS with ARH 1 7/8 LT w/Cats, Borla axel back, Fastlane CAI and SLP UP. I am curious to learn how I should tune my car with this setup. Timing advance and KS are like a nightmare to me. Any advice will be highly appreciated.
I would also zero out the Spark Correction GAS table, it adds timing to your main spark tables based on AFR.
2008 Corvette A6 - Comp Cams 231/239 617/624 109 ICL 113 LSA, Patariot Extreme Dual Springs .660", Milled .30" Stock LS3 Heads, Mahle -4cc pistons, FTI 3600 Converter, 1 7/8 kooks cat-less 3 inch X-Pipe, air raid intake, ported TB, SLP Loudmouth I. 512hp/464tq
2011 Ford Taurus SHO - stock with just a Tune
How much timing are you running?
I have to play with the KS in order to use this timing
Is it high?
It is to high, but its set that way from GM. The LS3's are efficient motors and they dont need that much timing.
So what's the recommended timing in this case? Any round numbers in peak TQ and HP?
How can you make gain in power without advancing the timing?
Zero out the table that madvette08 mentioned, and start off with about 22* of timing at your peak torque (roughly 4600-4800rpm) and 25* at peak horsepower (probably in the 6000rpm area). Smooth and try it out.
http://www.dsxtuning.com
Just say no to bull s***.
Around 23 degrees is were they like it, air fuel ratio is also important. What AFR are you running?
