Results 1 to 8 of 8
Thread: Error 11 Security Codes Denied
    I am trying to change my revs per mile with HP tuners and it is telling me security codes denied error 11. What should I do?
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,285
    Yes basically i was trying to tune a file i read from my PCM several weeks ago. I did a fresh read and then changed my revs per mile and it worked fine.
    What gives?
    HP Tuners Support
    (foff667)
    28,285
    If we knew it would be fixed.
    Why does HP tuners says erasing the TCM and then programming the TCM when I didnt make any changes to it? All I did was change my revs per mile field.
    HP Tuners Support
    (foff667)
    28,285
    Quote Originally Posted by wreedz71 View Post
    Because when you have a file that has both a pcm & tcm cal in it you must write both the pcm & tcm.
    So did it change anything? All i modified was my revs per mile. Just trying to understand what it is doing before i screw something up. thanks
    HP Tuners Support
    (foff667)
    28,285
    It will write whatever is in the file, if nothing changed it will still write to it, just nothing will change.
