Instant Alert LED's ie: High/Low Oct table in use!
If I could have a real time panel of simple labeled red, yellow, green graphical LED lights showing me what the PCM's current decisions/Auto modes that it is going into and what switches I setup... even real time current status LED Alerts... well, that would be so valuable when tuning/trouble shooting/logging... for example:
1) High Octane Table in use: Green / Low Octane Table in use: Red
2) Open / Closed Loop
3) Knock retard detected/activated/activity Red / Green for none detected
4) EGR Activated/Deactivated
5) PE status
6) Oil Pressure Alert... alarm, voice, flashing red, green for good
7) Lean mode activated or detected: RED
8) Miss fire detected: RED, None Green
9) IAT, EGR, ACT, AFR correction tables in use/activated
10) Trans Slip detected: RED... Green for normal
11) Abuse mode: RED
12) Shift speed: flashing Green for performance, green for normal, yellow/red for hot or abuse
13) CAGS On or Off
14) Fan function, on/off indication Green/Red
15) AC override activated: red/green/yellow???
Get the idea... Would be awesome... The ability to monitor and be alerted real time or even when reviewing the saved logged data/run would be so helpful when tuning and troubleshooting.
Dan
MileHigh427
