I finally got some pics of my turbo project fab. work complete and they are posted on pages 2 and 3 on my website in the signature, so check 'em out.
Well I started tuning today with HP Tuners and it was a great experience. I love the HP Tuners setup and it's pretty easy to use, even for a noob 18 y/o kid like me. I messed with the injector flow rate table and got the injectors pretty well compensated for the car, and after a little cranking it fired right up and there was no black smoke like before. We took it out with the vacuum line out of the FMU. It ran pretty good but leaned out up top, so my speed shop guy suggested to hook the vac. back up to the FMU and boom, it worked.
I have a wideband setup in my car and I was datalogging with HPTs and the A/F was 14 flat at idle and was steady up until the boost started on (which we could measure with the APEXi unit to the nearest .1 of a BAR and .01 of a mmHg vacuum). After boost kicked in the A/F ratio went to about mid 12 and the car loves it, no detonation at all. My speed shop mechanic is very good and even works on the JB Motorsports funny car (driven by Paul Lee) so I'm assuming he knows detonation when he hears it. No detonation occured even when we overboosted to 12psi (that was really fun btw).
There is one problem though, whenever we give it full throttle, once it gets to a certain point (after 5 seconds or less I'd say) the engine goes into "Engine Low Power" mode and throws, among other codes, a P1514. After that the car is limited to 15% TP (as HPTs indicated) and has virtually no power. This P1514 code has something to do with too much airflow vs. TP. After I clear the DTC codes it starts right up and we can use it with full power, until of coarse we drop the hammer and it throws a P1514. Does anyone have any suggestions as to what this could be and how to fix it?
Edit: There is no signature here, I forgot, the site is:
www.cardomain.com/id/njp98
