Results 1 to 4 of 4
Thread: #'s over or under max??
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    there are a few parameters & such where it exceeds the min or max amount for whatever reason. A couple of instances are OS 12211492 for an auto v6 fbody max tq vs gear in the file i have it has 1000 but the max is 640...when i change it to say 999 instead of 1000 it goes directly to 640. Also in automatch v8 ls1 cars under the transmission diagnostics tab TCC clear min slip has a negative stock value...if you try and change it it goes directly to 0 since this is the lowest value. Just wondering why the stock value migh tbe over or under the supposed min/max.
    Bill
    Advanced Tuner xonelith's Avatar
    Oct 2004
    Whitby, Ontario, CANADA
    408
    Re: #'s over or under max??
    Similar problem with the N-bodies:
    All Motor 2001 GA GT1
    Apr 2004
    Hurst TX
    101
    Quote Originally Posted by xonelith
    I have contacted HP and gotten no response on this.
    2004 Chevy 1500 CC 5.3L 2000 Pontiac GA 3.4L 1995 Pontiac TA LT1 1997 Camaro 3.8L
    the issue is this, the GM limit is very high (1280) and we have found thru extensive testing on V6 vehicles that this causes problems on all but GTP vehicles. Hence, we re-changed the limits back down to 640 for all V6 vehicles as this fixed the problem on all vehicles tested.
    Chris...
    I count sheep in hex...
