Results 1 to 17 of 17
Thread: *** EDIT Part 2*** a full reflash to newer OS
    Apr 2004
    Erie, PA
    464
    I have all the software and hardware for all the F-Bodys and C5 cars.
    I have a guy that has a 2000 Z28 A4 and I want to flash him to a 2001 or 2002 file so he will only have 1 VE table, how do you do it? I want to tune him Mafless.
    Just select a 01 or 02 file and do a full rewrite?
    Bill
    2001 Camaro SS M6 - 23,xxx Miles
    Huron Speed AC Turbo AC Kit - 6.0L 9.4CR, LS3 Heads, 226 232 115 lsa cam, Turbonetics 7575 1.15 AR Turbo
    10.98 @ 133 MPH on 9 lbs boost
    Nov 2002
    477
    Re: Need procedure to do a full reflash to newer O
    do a full rewrite w/the 01/02 bin
    Generally when I do this i try to make it as safe as possible... so I'll make sure the laptop is plugged into a wall outlet, car battery is charged, then I'll do a test full write first, if that works then I do a full write
    Mike Horist
    00 WS6 (TA) | 04 WS6 (GTP Comp G)
    Mike \\#at&\\ horist \\&dot$\\com
    BOTH cars HP Tuners Tuned
    Apr 2004
    Erie, PA
    464
    Sounds simple enough..
    About how long does it take to do a full rewrite?
    28,268
    2 minutes
    Jul 2004
    1,579
    One bit of caution first is that the 2000 VIN number will not be able to be used with the newer 01-02 program, different calibrations. Just thought I would remind some incase that was an issue (needs to keep VIN).
    Dec 2004
    40
    and relink the VATS if so equiped.
    More Than Zero
    Apr 2004
    Erie, PA
    464
    Ok guys, say I get a "new" PCM from GM that doesn't have a file in it, it's blank, can I flash a 2002 F-Body file in it and then it will work fine?
    Will I have to disable the VATS?
    Bill
    Jul 2004
    1,579
    Re: *** EDIT *** a full reflash to newer OS
    Just incase someone missed it ...
    No! It must first have a BIN file flashed to it. The dealer should be able to flash your VIN onto the brand new ECM (that is what we did). I speak from experience as I tried to flash a brand new ECM for a friend, but was unable. HPT couldn't identify the config codes to determine if I had access to read/write to the ECM. To use HPT, you need to have the config files flashed to the ECM for compatibility. Otherwise anyone would be able to flash to any ECM regardless of support.
    Yeah, it will need to be in a vehicle to use Tech II (through the OBD-IIport) to flash it ... at least that is how my local dealers do it. The good thing is you can use an F-body and swap it out in like a minute.
    Sep 2002
    Chicago, IL
    6,395
    We have modified the rules slighly in 2.0..
    2.0 should handle blank PCM's a little better.
    We got this guy Not Sure, ...
    Apr 2004
    Erie, PA
    464
    thanks guys
    From memory, you should be able to flash a blank one by just doing a rewrite entire. A blank PCM is the same as one in recovery mode.
    I count sheep in hex...
    Apr 2004
    Erie, PA
    464
    Re: *** EDIT Part 2*** a full reflash to newer OS
    No can do guys....
    I tried to reflash a 1999 LS1 PCM with a 2002 LS1 file and it won't work because I have two seperate cables.
    1 cable has 1999-2000 LS1 Cars and my other one has 2001-2002 LS1 Cars.
    So it looks like I'm screwed unless someone can help me out.....
    Oct 2002
    206
    Quote Originally Posted by Billiumss
    No can do guys....
    I can flash any PCM to any year and model with my Tech 2 and SPS.
    I can flash your file to your PCM also. I have 02 Fbody support. That get your started in the right direction.
    email me>
    Loyde
    http://www.fastfieros.com
    Oct 2005
    5
    So let me get this straight. If I want to go from a 1999 to a 2002 OS (the 2 years I bought),
    1) I download someone's 2002 bin
    2) Copy the tweaks from my current VIN that I've already done to it to the new bin.
    3) Select "Flash" "Write Entire" "Non Active Test" and make sure it will work.
    4) Assuming no error messages in in step 3, Select "Flash" "Write Entire" and watch it burn.
    I noticed 2 potential issues:
    1) "Relinking VATS" what is the procedure for that?
    2) VIN may not work. What is the fix for that?
    Nov 2002
    477
    Since you're using a 2002 Operating system, you won't be able to put a 2000 VIN into it (If you're concerned with emissions, you can just flash the PCM back to a 2000 w/a basic tune and the codes turned off... that's what I do)
    I've never had to do a VATS relink.. but if for some reason the car won't start after and th security light blinks... then do a VATS relink and you'll be set
    Mike Horist
    Nov 2005
    Quote Originally Posted by horist
    What do you mean by "if you're concerned with emissions?"
    1-The smog machine can't fail you for the VIN not matching the one entered for the test, and may not even check for it for all I know.
    2-Even if it did read it and the BAR red flagged your car..they can't do anything short of coming to your house and scanning your ECU.
    so i dont think emissions is a concern here.
    Jan 2004
    orlando fl
    79
    I have had people report on failing emmsions due to incorrect vin on the pcm. Basically, it is nothing other than somebody at the inspection station trying to create a fake passing for a friend using a different vehicle, if you think about it the way the state does.
    Glad I live in FL with no emmsions.
    Ryan
    1998 Ws6 TA
