email sent. Thanks again.Originally Posted by Chris@HPTuners
xon
Nick, we have found a minor issue that would cause that. It only applies to the EIO units.
It won't harm anything. The workaround is to just try a few times. It should go through after a couple of tries.
2.0.17 will have this fix.
We got this guy Not Sure, ...
Thanks! I downloaded ver 2.0. I still need to download frameworks.net from the Microsoft website. It would be nice to have it on CD in case HDD takes a dump. I guess I could copy the files to several storage devices just in case.Originally Posted by foff667
1998 Z28 Red/Gray HT, A4, 3.23
|Pacesetter, Hooker ORYP, Aerochamber|TSP Cam, PRC dual valve spring kit, LS2 timing chain|LS6 oil pump,|SLP Air Lid, P&P TB, FRA, TBB|Fuddle 3400 2.1, B&M cooler|GM iridium plugs, Taylor 8 mm|AMW catch can|J&M PHB & LCA's|HPTuners 2.1|HP House & Dyno Shop
Thanks Keith!
When will 2.0.17 be coming out?
[glow=red,2,300][shadow=red,left,300]Nick, we have found a minor issue that would cause that. It only applies to the EIO units.
2.0.17 will have this fix. [/shadow][/glow]
I'm having an issue with the scanner, it keeps comming up with "error failed to connect to resource" wile im scanning.
anyone else seeing this
More Than Zero
E-mail me your customer ID # and I can give you a new update to see if that fixes it.
Keith,
I tried to get 2.0 to recognize my cable several times by Flashing and I was getting same error code over and over. I tried scanning with it and it went right through. It has not give me any more trouble since. Just thought this might help someone else! I'm not sure why :huh2:but at least its working now. Its great by the way! I really like all the new scanner options!
Thanks Again!!!!!
ps What is the new VE error Histogram for? I have not had a chance to check it out?
On this Frameworks download....must it be digitally signed in order for me to get it and must it be gotten thru update. If so i have a pirated version and cannot do this......I dont believe. Help Please.
Originally Posted by Keith@HPTuners
2000 Impala 3.8
4T65Ehd 3.29
VCM ID:7DS739259ui
VCM OS ID:9387047
I already had .net but you should be able to download the file and install it even on another system. You dont have to use windows update.
2000 Impala 3.8
4T65Ehd 3.29
VCM ID:7DS739259ui
VCM OS ID:9387047
Version 2.0.16 Rocks!!
I'm trying to set up a MAF vs AFR Error Histogram as recommended. I know I plot for AFR error, what do I put in the x and Y axis? I tried maf hz vs maf in g/cyl and tried to build a table to plot against and it runs out of room. ???
Sorry didnt know the link on the login page went to windows updateOriginally Posted by Badassbird
Here
http://www.microsoft.com/downloads/d...displaylang=en
2000 Impala 3.8
4T65Ehd 3.29
VCM ID:7DS739259ui
VCM OS ID:9387047
You need to plot the MAF table in X axis and plot the AFR error. Then also log the required PID in the table display and it will work.Originally Posted by mac99
Well I found with the scanner that my kids 2000 GA 3.4L is putting out
in excess of 600 foot pounds to the trans.
Me think the calibration is off a bit there.
2004 Chevy 1500 CC 5.3L 2000 Pontiac GA 3.4L 1995 Pontiac TA LT1 1997 Camaro 3.8L
Keith,
I spoke to soon, I tried to flash to my truck this morning about 25 times and got the same error code over and over! I just put 1.7 back on and it still worked fine so it must be in 2.0. Any Suggestions? The 2.0 scanner was working fine, if I could only get the flash to work it would be great!
Thanks,
Nick
Nick, e-mail me your customer ID # and I'll give you an update to try.
holy crap! I have a lot of catching up to do. Glad to see 2.0 finally made it to the world!
Eric - 01 Silverado 5.3 ECSB
ET: [email protected] 1.77 60' 5200 lbs
Crappy website about my truck
My Myspace page
Usually contains explicit material (language, etc..)
It's Peanut Butter Jelly Time!
Thanks Keith! I will give it a try and let you know if it works!
Great Customer Service!!!!!!!!!!!
Thanks 12secSS...That did the job!
