Does this increase the spark table size as well, or is the spark table still limited to 1g/sec?
1998 Ws6 TA
the spark table is not extended.
I count sheep in hex...
what does the new spark table now look like, wasnt before it based on MAF sensor and rpm?
now that the maf is gone how is it referenced?
dynamic air and rpm
what are the units of dynamic air?
and what sensor is it reading off of?
units are grams/cyl (it the mass of air in the cylinder).
this value is calculated from the MAF and/or the VE table. If you have the MAF removed then only the VE table.
ok i was just wondering how you control the spark if you remove the MAF.
so your saying it gets its inputs from the MAF and MAP, so if you remove the MAF, it only gets the values from the MAP
how long till the 3bar map is out, ill be eager to try it out before summer..
TTT when will the 2-3 bar upgrade be released for us 98 guys?
Going to push more boost here soon and would love to have this feature already.
Jeremy
98 Formula A4 |DIY'er Racing Turbo Set Up|9.1 comp Forged internal Block|ROCK ON Stage 4 4L60E|Vig3800|HPT/Synergymotorsports assisted Tune|
