06 cobalt ss and po315
Hi I have a hp tuned 06 ss sc and I have a po315 can I use hp tuners to relearn or is it a dealer only fix? ? The car runs so I think it is the cam sensor.. thanks
yes you can do it, make sure the sensor was installed correctly (cyl 4 TDC compression stroke i believe) or you will never be able to do the procedure properly
Need to reinstall cam sensor barring that the sensor isnt bad.. relearn wont work
Good old Cam Sensor relearn huh?
iam having the same problem how do it perform the relearn i posted a tread for this
