Results 1 to 20 of 21
Thread: Help with Idle Tuning
    Jul 2006
    Golden Meadow, LA
    59
    I changed from the stock intake manifold & TB to a F A S T LSXrt manifold and a 102 mm TB, I also changed Cams, from 226/226 .585/.585 112 LSA to 226/230 .598/.600 113+2 LSA. I also had the heads shaved .050.The engine is a 5.3 with stock bottom end I'm having trouble with the idle and I've never tuned for idling before. What do I need to scan to find out where my problem is. I'm not sure what PID's to set up in the primary table. Please keep it simple. The Idle in gear is not bad but in neutral it starts up at about 2000 then slows down for a little while, around 900 then it speeds back up then slows down then stops. If I touch the accelerator it speeds way up.
    '99 Silverado ECSB w/5.3, Patriot Performance Heads (2.02in 1.57ex) milled .050, LSXrt intake w/FAST 102mm TB, Comp/EPS Cam (226/230* dur .598/.600" lift 113 +2 LSA), 44# injectors, LS7 Lifters, Stock Rockerarms, Double Roller Timing Chain, ARP Head & Rod Bolts, HV Oil Pump, Vigilante 9" Converter 3600 stall, FLT Level 5 4L65E, K&N 77 series, Pacesetter LT, No Cats, Magnaflow Mufflers, True Duals, TB Bypass, Truetrac, 4.10's, E-Fans, HP Tuner
    '10 Camaro 2SS/RS RJT, L99, A6: Stock
    Jul 2009
    Noble, OK
    317
    This is on the 99?
    DBC?
    Jul 2006
    Golden Meadow, LA
    59
    yes it is
    Nov 2007
    MI
    686
    Have you tuned your maf and ve table yet? That's the first step.
    2018 Camaro SS, Maggie 2650, 103 TB, Big Gulp, E85
    Jul 2006
    Golden Meadow, LA
    59
    VE table is off,when Maf is disabled but looks good when maf is enabled. within 4% with MAF enabled
    Nov 2007
    MI
    686
    that's because when the maf's enabled it's using the maf. You need to disable it and THEN tune the VE table.
    Jul 2006
    Golden Meadow, LA
    59
    ok I understand I need to disable it to tune VE table ,but since the VE table is within 4% on the trims with it enabled is it ok to assume the MAF is tuned?
    Jul 2006
    Golden Meadow, LA
    59
    NO thoughts or opinions?
    I'm working on the VE table
    Mar 2010
    Texas Hill Country
    3,299
    No. You can't tell what the VE is unless the MAF is disabled and you can't tell what the MAF is unless VE is disabled.
    Jul 2006
    Golden Meadow, LA
    59
    OK thanks, i was thinking that if the ve was good when the MAF is enabled that the MAF was tuned. I still got a lot to learn, but i'm reading what I can and trying to understand it all.
    Tuner mrfister77's Avatar
    Mar 2009
    norman,ok
    138
    What do you think of that intake and tb?
    Jul 2006
    Golden Meadow, LA
    59
    Quote Originally Posted by mrfister77 View Post
    It pulls hard with the FAST Intake, the throttlebody right now not sure until I can get it to idle. SO far it's showing a big improvement over stock.
    I haven't been able to work on VE table any more lately, I'm getting my shrimp boat ready and we just came back from Camaro5 Fest in AZ.
    Jul 2006
    Golden Meadow, LA
    59
    I believe the VE table is good, here is my last scan log and tune, MAF is still disabled
    Aug 2009
    Calibrating
    3,377
    To be honest I would make sure the IAC counts are in order (around 60) then I would do the Russ K Idle config. Your basically just running a cam setup with a little better induction. After these two things then I would work on VE then on the MAF. For starters on the VE table lower the everything from 1200 down by .60 from the factory VE table, somewhere in the midrange the VE table will match factory and then start to be higher.
    BTW are you starting out with a 5.3 file or LS1 file?
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Jul 2006
    Golden Meadow, LA
    59
    Before I changed the intake manifold and Cam it was idling good,I already had an aftermarket cam tune. now it won't idle, I was told to tune in VE table first. I do have the original LM7 tune with original '99 ECM.
    1) What is the correct PID to insert to scan IAC count
    2) I'm not sure how to do the multiply by % thing never did it.
    3) Can I find TPS voltage in HP Tuner or do I use a voltmeter? If using a voltmeter, I just put the red point on 1 wire and the black on the other wire?
    Jul 2006
    Golden Meadow, LA
    59
    Anybody
    Aug 2009
    Calibrating
    3,377
    Find the Russk Idle config on here ( several post about it) it has a histogram with all the pids you will need including IAC, TPS, etc.
    Use a voltmeter on the TPS to see what the voltage is, I am an LTX engine so its probably different, but ground goes to black and power goes to blue to see voltage.
    14 Gen 5 Viper
    Jul 2006
    Golden Meadow, LA
    59
    Thanx Ben
    you need to model the airflow (the VE) before you do anything and looking at your second question, I dont think you have changed the VE table any, bc it is necessary to use that function to fix the error in the table.
    I would do the VE before I run any of the RussK stuff.
    Injector data>good ve table>MAF (Optional)>fine tuning idle, hot starts...
    2003 Chevrolet Silverado SS
    L92 Heads/ L92 Truck Intake
    OBX LT Headers
    Custom Ridings 3200 Stall Converter/Built Trans
    6 Piston ZO6 Brakes/ 2 pc 15" Front rotors
    Tuner copley87blazer's Avatar
    Mar 2011
    Wilder,ky
    131
    Ve first, if you can get it to idle at all, or it stumbles at idle raise the idlle rpm 100 or so
