Hi All,
I've got a KB blower-equipped 06 GT at the shop here.
I inputted the correct injector data as per Ford Racing site and elsewhere on HP Tuners. And the MAF curve is pretty well dialed in too.
The car runs quite well on the dyno, but AFR oscillates around the commanded value by + or - 5%, and I see that the commanded pump duty cycle (and therefore voltage) seems to move very slowly while over and undershooting its target 39 psi pressure drop across the injectors.
Can the boost-a-pump's presence require the fuel pump's PID control to be tweaked?
Or shouldn't it make any difference?
Thanks!
