Results 1 to 11 of 11
Thread: 3bar screenshots
    3bar screenshots
    Here's some shots i just took today My lowly 8 PSI doesn't get me too far into the 3bar MAPS... :-[
    5kpa resolution 15-105kPa
    10 Kpa resolution 105-315 kPa
    Scanner histogram:
    VE Table:
    I count sheep in hex...
    Sep 2004
    St. Louis, MO
    123
    Re: 3bar screenshots
    that is awesome
    Victor&&99 T/A WS6 &&TEA 5.3 heads, 224, .581 112, Mac Mids, ORY, SLP Loudmouth, SLP Flowpac, ASP pulley, BMR PHB, LCA\'s w/relos., SFC\'s, Vig 3600 w/ 4L65E,deep pan, B&M transpak, Hayden trans cooler
    Mar 2004
    Germantown, MD
    362
    hook it up!!
    -Bill
    2000 Camaro V6 Boltons and a tune
    Jan 2004
    orlando fl
    79
    looks good.
    What about map based spark values? Is that possible?
    Ryan
    1998 Ws6 TA
    Quote Originally Posted by 1998WS6
    looks good.
    Ryan
    would you base it on RPM and MAP pressure?
    ya i was wondering the same thing for us guys who will be going MAFless.
    you don't need it, the Cylinder Air axis on the spark tables is calculated from the VE table and is a more accurate measure of "load".
    Chris...
    Nov 2004
    10
    FEED ME ;D
    IS there more than one 3 bar map from GM or do you have to make the GN style work?????
    Advanced Tuner arthansen's Avatar
    Apr 2004
    Tampa, FL
    425
    Chris, the problem with the spark table is the Histogram. In a MAFless setup, the Historam only records data in one row. How can we log spark data and relate that data to the PCM tables?
    2013 Jeep Wrangler JK
    3.6 V6
    More MODs than Stock
    2018 Ram rebel
    5.7 Hemi V8
    Stock
    i will fix the v6 cylair PID very soon. I have to do it for all V6 cals we support so it takes a long time as GM don't make it easy to extract this PID using normal techniques. We presently support 150+ V6 calibrations. I hope to have it done for 1.6 but time is running out, regardless it will be in 1.6.0 or a maintenance release soon after eg. 1.6.1.
    Chris...
    Apr 2004
    Tampa, FL
    425
    Thanks.
    3.6 V6
    2018 Ram rebel
    5.7 Hemi V8
    Stock
    Quote Originally Posted by Chris@HPTuners
    Chris...
    ok you lost me, sorry im still trying ot get the tunning thing down.
    now what are the values you enter in on KPA vrs. RPM
    where would you then go to adjust the timing and spark?
