Page 1 of 10 12345 ... LastLast
Results 1 to 20 of 197
Thread: Announcing VCM Suite v1.5 !!!
    HP Tuners VCM Suite v1.5
    HP Tuners is happy to announce the release of VCM Suite v1.5. This release includes some very substantial feature and usability enhancements as well as some major core software structure changes to prepare us for the future. We are also proud to announce with this release we begin shipping of our new Enhanced I/O (EIO) Interface hardware with four analog inputs (for sensors such as WBO2, EGT, etc.) and also, in an industry first, two scanner controlled outputs that can be used to drive control relays and/or various LEDs/lamps.
    We hope you enjoy these new features and functionality as much as we enjoy your candid feedback, idea's and support along the way.
    The HP Tuners team.
    Major Features
    - Enhanced I/O Interface hardware (4 inputs, 2 outputs, customizable)
    - PCM Controls included in base VCM Scanner (no extra charge)
    - VCM Scanner supports status bit monitoring
    - VCM Editor allows viewing of all binary files
    - VIN change option in VCM Flash
    - many new V8 and V6 editor parameters (100+).
    - Minor cosmetic improvements and new tabs for a cleaner layout
    - Injector scaling added to the tools window.
    V6
    - Supercharger Boost control (Boost Timer)
    - COT
    - VATS
    - Diff Score Abuse
    - Gear Select Abuse
    - Traction Control Torque Management
    - Supercharger Torque Management
    - EGR disable IAT
    - MAF Delta Airflow limits
    - Closed Loop Enable Delay
    - Max Torque vs RPM
    - Speed limiters (1 and 2 injector disable)
    - Drive Sprocket (chain) ratio
    - Acceleration Enrichment (AE)
    - Deceleration Enleanment (DE)
    V8
    - Trans upshift/downshift pressure modifier tables
    - Trans overtemp DTC thresholds/timers
    - additional Closed Loop Fuel LTFT paramters
    - additional Knock paramters (Tip-in, gain factors, burst knock)
    - Spark MBT timing
    - additional Torque management
    - Ignition off Fan temp/timers
    - MAP Perf Tests (P0106)
    - Idle IAC Airflow Fan Compensation
    - Transient Fuel parameters including Warmup compensation, and Injector to Cylinder fuel mass flow values
    Resolved issues:
    - Change Idle RPM to AIR Pump on/off, instead of AC
    - display InjFlowRate imperial in lb/hr
    - increased Spark table limits
    - increased torque management limits
    - fix Speedometer for 03/04/05 M6 V8 vehicles
    VCM Flash
    - 05 Support added for many vehicles
    - VIN modification option added for all users
    Resolved issues:
    - various new operating system support added
    - New chart with user configuration, zoom and more options
    - Table display can be resized with drag and drop
    - Optimized scanner engine
    - Better disconnect/fail detection routines
    - Integrated wide band and aux sensor support implemented
    - Improved cosmetics and useability
    - Improved reconnection code for communications loss during scanning
    - Added Emissions and Readiness status support
    - Improved histogram for V6 vehicles
    - PCM Controls added including various on/off, PWM and Transmission controls. Also, includes CASE learn and cylinder balance test. (exact capability varies with year/model/engine)
    - Status bit monitoring capability (Fans, AC, etc.)
    Resolved issues:
    - Fixed overflow error when exporting very large .hpl files to .csv
    - Fixed export timestamp
    Ordering and Pricing
    Ordering will be activated on 28th Oct, 2004. Shipping will begin next week.
    Software
    Existing customers with software support (thats everyone) will be notified via email when the VCM Suite v1.5 software upgrade is available for download via our customer login page http://www.hptuners.com/login.html
    Existing user (Std and Pro) special upgrade price (order before 12th Nov 2004): $75 + shipping
    - existing interface must be returned to HP Tuners before new interface will ship. Send the interface ONLY! Keep your cables. Just send the black box.
    - Std I/O packages that are ordered after 29th Oct, 2004 are not eligible for this special upgrade
    Enhanced I/O upgrade price (after 12th Nov 2004): $150 + shipping
    VCM Suite Std: $499
    VCM Suite Std with Enhanced IO: $649
    The Enhanced IO interface will ship with all VCM Suite Pro packages at no extra charge.
    EIO Upgrade/Return Process
    The following process will be used for upgrading from Std IO to EIO interface hardware:
    - order either via paypal to [email protected] or via certified check or money order payable to "HP Tuners LLC" included with interface
    - ship interface in a padded envelope to:
    HP Tuners LLC
    P.O. Box 801057
    Valencia, Ca 91380-1057
    - When you ship your interface you MUST include your full name, e-mail address, phone # and return ship to address in CLEAR PRINT with your interface. Also, information sent via e-mail conversations will NOT be used for processing. You MUST include all relevant information with your shipment to us.
    - please register or insure your shipment as lost interfaces will not be replaced.
    - returned interfaces will be checked before new interface ships.
    Shipping charges are as follows:
    - US$10
    - Canada $15
    - all other places please email [email protected]
    Once again, thanks for your continued support!!
    HP Tuners.
    I count sheep in hex...
    Sep 2002
    Chicago, IL
    6,395
    Re: Announcing VCM Suite v1.5 !!!
    New status bit display:
    Output Configuration display:
    New VCM Controls:
    User Configurable inputs:
    Input and output in action
    We got this guy Not Sure, ...
    Apr 2004
    Bakersfield, CA
    592
    WOOOOOOOOOOOOOOOOOOHOOOOOOOOOOOOOOOOOOOO!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Any ideas on what the turn around time will be on shipping out the new cables once you have received ours?
    Eric - 01 Silverado 5.3 ECSB
    ET: [email protected] 1.77 60' 5200 lbs
    Crappy website about my truck
    My Myspace page
    Usually contains explicit material (language, etc..)
    It's Peanut Butter Jelly Time!
    Oct 2004
    Orlando FL
    766
    1) Does this mean new users can order on or before 10/29/04, pay $499+$75+$10 and you'll just send the VCM Suite 1.5 with the EIO cable? Or would we have to wait for receipt of the old cable and ship it back into you?
    2) If not, I presume the $499/$649 prices include shipping as it's not specified?
    3) Standard 6 month's worth of updates still included or has it changed?
    1998 NBM Camaro Z28
    LS3 motor
    Mod list
    I just sent you money via Paypal for the upgrade
    I will be sending my interface tommorow. Thanks for the awesome price for upgrading.
    Sep 2002
    Chicago, IL
    6,395
    Jim,
    1) All new orders of VCM Suite with our Enhanced IO interface will cost $649 + Shipping. We just picked the date of Friday to help any possible confusion during the transition. We assume orders between now and friday will be for the current version they want in the future. We do not expect orders placed between now and friday to be returned to us for upgrade.
    2) Those prices do not include shipping as our products and checkout page indicate.
    3) Standard 6 months is still included.
    For existing trade-ins, an additional 6 months of software upgrades will not be included do to the the low upgrade price.
    Oct 2004
    Orlando FL
    766
    Not sure if you can answer this, but which LM-1 wideband components do I need to use your EIO with it? The RPM converter? The AuxBox? Neither/Both?
    It seems like I just need the LM-1 base kit, which includes an analog output cable..?
    1998 NBM Camaro Z28
    LS3 motor
    Mod list
    May 2004
    Streamwood, IL.
    196
    so its $85 total for upgrading?
    Dave
    75.00 + 10.00 Shipping if your in the states.
    Advanced Tuner Screamn03's Avatar
    Feb 2004
    Vacaville, CA
    832
    Sweet, but I can't download it yet . Is this the tease of all teases. LOL, J/K, great work guys .
    -Michael Rudolph-
    2003 Redfire Cobra
    Eaton Powered to a:
    11.301 @ 129 1.68 60' MT DRs
    11.85 @ 124 1.90 60' street tires
    May 2004
    AUSTRALIA
    839
    I dont need the CAD interface as I have an early '04 Monaro...
    Do I still need to buy the upgrade to use Wideband inputs?
    Will the std. v1.5 version with my existing cable work with wideband?
    If I do upgrade, and get a enhanced interface, will it work with OBDII and CAD interfaces?
    Sep 2002
    Chicago, IL
    6,395
    The Enhanced IO interface is not our CAN interface.
    If you wish to use our product integrated with a wide band interface you will need to upgrade to the Enhanced IO interface as our current interface has no provisions to hook up to any aux. inputs or outputs.
    Sep 2002
    Chicago, IL
    6,395
    What our Enhanced IO interface looks like:
    Oct 2004
    So Cal
    8
    Sweet!! ;D I ordered already... mailing it in the morning. Nice job guys!
    1999 Magnacharged FRC&&1999 NBM SS M6
    Tuner in Training 03Quadrado's Avatar
    Oct 2004
    Santa Cruz, California
    36
    Very nice! Now i dont know if i even want to learn how to use the old version. Lol. Waiting impatiently for the email...
    2003 HD Silverado 6.0 4x4 w/Quadrasteer 36" Michelin ZXL (255/100R16) (9.00R16)
    Aug 2004
    Qld Australia
    166
    Sounds like you have included some great features, tremendous job guys and Thanks!!
    I have two questions...... I purchased my package through the Aussie distributor, can i return it to them for the upgrade or do I return it to the USA? and, If I can upgrade through the aussie distributor, when will it be available?
    Cheers
    Brian
    Apr 2004
    East Tennessee
    339
    I am in the customer login screen, BUT it only shows the 1.4.0 download file!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    What gives???
    2007 CTS-V LS2
    Apr 2004
    Bakersfield, CA
    592
    Quote Originally Posted by SideStep
    What gives???
    They said you will receive an email when it is ready for download.
    My Myspace page
    Apr 2004
    Bakersfield, CA
    592
    Keith, do you guys have pricing for extra pigtails?
    My Myspace page
    Just ordered, the cable is in the mail.
    2002 Quick Silver Z06 - Breathless Performance Shifter, DynaTech Headers SwainTech Coated, A&A Vortech Kit
