Originally Posted by ZUKI
ditto :
ditto :
Done.. I'm sure there will be new posts made though. :'(
We got this guy Not Sure, ...
I take it then, there's no chance of getting the cable swap going ahead of time time then huh?
98\' T/A, filter/lid, Comp 212-218, 85mm MAF
yes, and no. I don't trust my O2s. Plus they never read the same. The driver side is always about 40 milivolts higher. So I don't know which one is closer to true.
I think he's talking about stuffing the wideband analogOriginally Posted by Magic_Chicken
output to either the A/C pressure sender (0-4V output)
or the rear O2s (0-1V output) and pulling it through the
regular PCM data stream.
Any word on the projected release of ver. 1.5?
98 M6 TA, mods: tsp torquer(233/233 .589 112), Patriot golds, ls6 oil pump, ls6 intake, tsp lid, pacesetter LT\'s and ORY, magnaflow, fra, HPTUNER!
very very soon.
So I went digging around in my buddys garage for the cyberdyne gauge voltages.. and well.. i found the instructions but they did not have the voltages on there..Originally Posted by Keith@HPTuners
looked online and no sutch luck..
I did however get their phone number
724-258-8440
I think it would be best if you all asked for the info. I think they will be more likly to give it out to you all..
if not i will try..
and if that dosent work i will take a voltage meter to it.. map a much of points.. and fit a curve to it..
let me know
-Bill
2000 Camaro V6 Boltons and a tune
Ok its 1st of October is it soup yet!! ;D
Running a little behind, but nobody will be left out.
Besides some extreme changes in the scanner, we are adding lots of new things to the editor.
List to date:
Fixes:
- Force Motor Current Temp axis
- Brake Shift Pressure vs. Torque vs. Gear Indicators backwards
- Throttle Follower KPH axis
- Increased Main/Base Spark Limits to + 60 Degrees
- Inj Flow rate displayed in lbs/hr (Imperial Units)
Transmission Parameters
- Trans 1->2 Upshift Pressure vs Trans Temp vs Torque
- Trans 2->3 Upshift Pressure vs Trans Temp vs Torque
- Trans 3->4 Upshift Pressure vs Trans Temp vs Torque
- Trans 2->1 Downshift Pressure vs Trans Temp vs Torque
- Trans 3->2 Downshift Pressure vs Trans Temp vs Torque
- Trans 4->3 Downshift Pressure vs Trans Temp vs Torque
- Upshift Pressure Mult vs. Trans Temp vs. Gear
- Trans_Overtemp_SetTemp
- Trans_Overtemp_SetTimerThresh
- Trans_Overtemp_ClrTemp
- Trans_Overtemp_ClrTimerThresh
- Trans Desired Torque
Closed Loop Parameters
- Switch = LTFT
- LTFT Min ECT
- LTFT Max ECT
- LTFT Update Rate
- Integrator Rich Lean %
- LTFT Min % Learn
- LTFT Min Map vs Baro (Table)
- LTFT_Min_MAP
Knock Sensor Calibration
- KR Tip In TPS (Knock Level)
- KR Tip In RPM (Knock Level)
- KR Normal Vs Cyl (Level vs RPMvs CYL)
- KR GlobalGain (Gain vs_RPM_vs_MAP)
- KR GlobalGain (Map_vs_Cyl)
- Tip In Min TPS
- Tip In Max TPS
- Tip In TPS Delta
- Tip In Min RPM
- Tip In Max RPM
- Tip In RPM Delta
Burst Knock Calibration
- Burst Knock Retard Vs_ERT_vs_Cool (1Mb Cals)
- Burst Knock Mult Vs RPM (1Mb Cals)
Spark Calibration
- Max Torque Timing vs. RPM vs. Cyl Air
- IAT Spark Advance Correction - Mult
- Max Torque vs. RPM
- Tip In Torque by Gear
- P0106 Error MAP Calculated Max Table
- P0106 Error MAP Calculated Min Table
Fan Calibration
- Ignition Off Fan Disable Temp
- Ignition Off Fan Run Time
- Fan 1 On Airflow
- Fan 1 & 2 On Airflow
Ken
How much of these things will pertain to us SC V6 guys ?
2000 Grand Prix GTP 11.586 @ 118.20
Best MPH: 121.72
New Ride: 04 GTO no times or anything yet
I ordered your S/W a few days ago. Its on backorder. Is it possible to pay the difference for the A/D cable prior to you shipping my order?
I would like to avoid the hassle of mailing back the original cable .
2000 M6 SS Convertible, FTRA, Lid, LS6 intake, LS6 S heads, TR220, RT cats, Magnaflow, paint chips on pass side door.
Did you not see Ken's post from yesterday? It's 3 above yours.Originally Posted by AnotherUser
Eric - 01 Silverado 5.3 ECSB
ET: [email protected] 1.77 60' 5200 lbs
Crappy website about my truck
My Myspace page
Usually contains explicit material (language, etc..)
It's Peanut Butter Jelly Time!
The masses have been antsy (me included) for coming up on a month now. Here's the thing, the more time they spend answering our questions, especially the repetitive ones, the less time they have to work on what we are waiting for. He gave us an update yesterday, unless 1.5 was released today, how much more of an update would you expect less than 36 hours after the last update?
Not getting fiesty, just being realistic.
PS: loved the "hi" thing, it was amusing.
My Myspace page
[quote author=AnotherUser link=board=vcmsuite_general;num=1094708466;start=2 0#36 date=10/04/04 at 22:43:12]
The masses are getting antsy...it's not like we are waving torches and pitchforks...
NOW! Thats funny Chit!!
yeah, hold your horses.... I have been waiting on v1.5 since like june 30th.
Keith&&99 camaro - cam & bolt ons&&13.65 @ 101 239rwhp/244 rwtq&&- in badly need of a real tune, help us v6 cats need more tables openned -
> I cant wait for 1.6
;D trying to start the new "cool" thing to be ancy about topic..
rofl.. I lvoe how you all keep us informed about product development!
keep it up.. yes we are all excited.. but keeping us informed is better IMHO then missing a release date and having people upset..
as long as the wait is worth it.. I must say it has been for all the previous releases..
-Bill
I would rather wait for it to be released when it is fully tested and READY, then get some rushed, slopped-together software.
Perfect example: "Microsoft Internet Explorer" ;D
[move]HPTuners rocks! 'nuff said. [/move]
Ry
I'm headed to the barn, goin' grab a pitchfork. ;D
v1.5 cool, but all I want is the A/D cable.
I like this talk about 1.6.
lets take some pressure off of 1.5 God knows you guys sure are piling it up.
... gasp.. choke.. chest pains.. ... ahh wait.. just some indigestion from another night of pizza and mountain dew chained to my desk.
