Results 1 to 10 of 10
Thread: Wouldn't recognize interface
    Jul 2011
    1
    Loaded tuner to this computer but for some reason it wouldn't reconize the connection.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,287
    Check to make sure the drivers are installed properly
    Jun 2011
    29
    How do you check that exactly???? mine was was working fine till i was reading the vcm and my laptop battery died... (not flashing the vcm)
    HP Tuners Support
    (foff667)
    28,287
    The USB device manager should show MPVI A & MPVI B
    Jun 2011
    29
    i dont see any thing like that under ports or the universal serial bus controllers..??
    i also did a seach for them on the computer and it didnt find anything...
    HP Tuners Support
    (foff667)
    28,287
    When you connect your interface to your laptop does the green power light illuminate?
    Do you hear two distinct dings when you connect it to the laptop?
    Jun 2011
    29
    ok went and tryed it agian and it works....... I didnt change anything... i cant win!!!!
    thanks for the help!!!!
    HP Tuners Support
    (foff667)
    28,287
    Doesn't it always happen that way, problems problems problems then when you try to diagnose the issue it works perfectly lol.
    May 2011
    Tulsa
    45
    Bill,
    I keep scanning my car with the laptop and it shows it just fine when I go to play them back it says interface was not found. Verify itis connected properly and the vehicles diagnostic port has power. 03 Z06 Vette. It was working fine and the system decided to reboot so I pulled the cable but after that it still worked fine. what is up... I also can not read my old scans I store them on my laptop is shows them but they wont read on the scanner.
    Regards
    Kelly
    03 Z06 Magnacharger, Borla stingers with XP Stainless Headers,KB Boostpump, 42 lbs injectors, 160 stat. CAI3.TPS Motorsports 427 Shifter. AFX Powerdex wide band. TIC clutch master.Monster stage3 with 18 lbs flyweel. AFX wideband. 10LBS boost. ALKYCONTROL methanol injection. DTE Trans Brace, Built MN6, NGK Iridium 7IX , 2 Bar MAP.
    [email protected]
    www.haysauto.com
    HP Tuners Support
    (foff667)
    28,287
    I don't understand the question or issue. Your interface doesn't need to be connected or found to PLAYBACK a file. Sounds to me like you are trying to RECORD a log while not connected to your interface and vehicle. This is NOT an issue with our software and rather an issue what what you are doing specifically.
    To playback a file simply open it or drag it into the scanner and hit play.
