Trouble saving scan log
I took the car out today to do VE Tuning, and got a bit nervous about the results, so instead of just pasting by percent, I figured I would save the histogram data to review while back indoors. Turns out I was using Primary VE/ RPM/MAP and not MainSpark/AirMass/RPM as instructed. So I am glad I did not apply any changes from that brief outing. Now all that said, I am still wondering why when I open a saved scan log, the table under histogram 3 (the one in use here), the cells are empty? Does it only save your results if you are using the proper histogram?
Thanks for any insight.
By the way of this, in the Tuning School book it says to expect LTFT to be near 5% barring some kind of vacuum leak. I seriously doubt I have any mechanical issues with the car. Running Blackwing and LongTubes as the only mods, and these things were put on with good attention to fitment. My LTFT numbers are above 10% any time not idling. Curious if this is normal.
Load the log, go to histogram, right click on it, click load all data.
Thanks! I see the data now. This has been a great help.
