Results 1 to 6 of 6
Thread: 3-1 and 4-2 skip shift
    Jul 2004
    Denver,CO
    12
    i have heard of this before and i know other competitors which will remain nameless say they reprogram the pcm's for the skip shift. can this really be done and if so what is the correct way to do it.
    Advanced Tuner arthansen's Avatar
    Apr 2004
    Tampa, FL
    425
    Re: 3-1 and 4-2 skip shift
    What type of car are you talking about?
    2013 Jeep Wrangler JK
    3.6 V6
    More MODs than Stock
    2018 Ram rebel
    5.7 Hemi V8
    Stock
    Jul 2004
    Denver,CO
    12
    i have a 2001 oldsmobile alero which is supercharged it has the 4T45E.
    Apr 2004
    Tampa, FL
    425
    I have no idea. The only GM cars I have ever seen with skip shift are the LSx cars. They have the skip shift feature and can be programed to lock out certain shifts.
    3.6 V6
    2018 Ram rebel
    5.7 Hemi V8
    Stock
    Mar 2005
    4
    To change your "skipshift" you just have to change your SHIFT SPEED vs. %TPS vs. SHIFT By changing these values, it will allow you to change at what speed (mph) your car will shift. Also, this isn't a "skip-shift"... even though the competitors say it is, I have had their tuning, and all it does is downshit say from 3-2, then 2-1. Your car will do this now if you slowly accel up to about 32mph (light throttle) you should be in third gear if slowly cruising. Now, punch it, and you will experience "skip-shift"....hope this helps ya.
    -Jared
    Oct 2005
    Duluth, MN
    35
    Well, the argument was that Skip shifting performed a release of two simultaneous clutches and time aligned their apply for the exact RPM needed to prevent clutch slip during the engagement on "kickdown" The idea makes sense, but whether or not "competitor" tunes actually do this is unknown.
    -A
Similar Threads
  1. Started 'tuning' my 4.2L I6
    By 2000Firehawk in forum GM L4, I5, I6 Tuning - Engine
    Last Post: 03-17-2024, 04:57 PM
  2. A4 Shift point tuning
    By Bill@HPTuners in forum GM V8 Tuning - Transmission
    Last Post: 09-19-2012, 07:46 PM
  3. Can hp tuners turn off skip shift on the ls1's
    By spaz in forum GM V8 Tuning - Engine, Gas (Gen 3)
    Last Post: 05-04-2007, 06:33 AM
  4. 2-3 shift problem
    By FloydSummerOf68 in forum GM V6 Tuning - Transmission
    Last Post: 03-01-2006, 04:43 PM
  5. Skip Shift operational at the 3~>4 shift only?
    By DarkblueTA in forum GM V8 Tuning - Transmission
    Last Post: 09-19-2004, 06:14 PM
