Results 1 to 8 of 8
Thread: 2003 Regal with built trans 3.29s need tune
    Aug 2011
    23
    I know I dont have a performance shift button but I still have the options in the editor for it.
    I have a s1x cam and would like to set up my new trans with a good tran settings
    I been taking the stock file and autochanging it to 3.69 etc....
    anyone have anyone recommendations or files they would like to share?
    Bob
    Aug 2011
    23
    also what good is the perf shift tables when I have no perf shift button? Is it automatic based on TPS?
    Aug 2011
    23
    blowing the dust off.... I use beta any trans expert wanna take a look?
    Aug 2011
    23
    current tune stock? 2003 regal trans settings
    Advanced Tuner Phantom's Avatar
    Jan 2008
    Louisville KY
    200
    The performance shift table is only set to work when you have the performance shift button if you do not and want those settings copy them over to the normal shift tables. Do not auto adjust the trans settings for gears you do not have.
    02 VW Golf
    98 Bonneville SSE
    03 Grandprix GT
    EcoModder
    Jun 2011
    19
    Phantom in his post he says he has 3.29's. here is my setup crazyguy if you want to take a look. its pretty much stock except for the 3.29's and rpms and minor tweaks. 98 regal gs
    Aug 2011
    23
    Thanks boss, I wanted to see if anyone with a 01+ regal can confirm that those performance tables are automatically used based on TPS or etc...
    Sep 2009
    Angola NY, (Buffalo)
    202
    Hey guy's take a look at mine.
    Bob, copy the trans table's onto yours and perhaps Justin's too. see how you like them. I have been running these setting ever since I had my trans rebuild.
    And mine is barely above stock. ( ~100K ago)
    The Regal has been laid to rest..... rust
    Now have an 06 Lucerne with the 3.8 and wishing HPT would cover that car
    Loved my 2001 Buick Regal GS.
    With more than 334,000K, 3.4 & 3.6 pulley, Change stats and pulleys with the seasons, Upgraded grounds & power wire, Volt booster, Caspers timing commander(AKA happy knob), Spectra intake-fender wall, PLog, 3" DP & 2.5 exhaust, HPTunner 12" Impala duel piston front brakes, New trans,GMPP suspension... yada, yada...
