Modify traction control settings
I have tried to change the target rpm for traction control by changing the base setting of 1500 to higher and lower numbers but after flashing these new setting the function is not changed the rpm limit of 1500 while gas and brake pedal are active continues to be unchanged regardless of what number I enter while using a beta version of HP Tuners program. Have any of you changed the rpm acheved while foot braking with traction control active by changing/reprogramming using beta version of HP Tuners?
