Results 1 to 10 of 10
Thread: Adaptive idle wont move
    I've got a 98 corvette that is being a PITA. Its got a fairly large cam and for some reason the adaptive idle trims STIT/LTIT wont move, they are glued to 0. Its a stock tune from the factory with no mods in those tables with the exception of dropping the min coolant down. What would cause the adaptive idle to not respond and try to correct idle issues?
    Phil
    1999 Corvette Coupe
    Worlds Fastest 346" N/A Coupe
    ProStreet Motorsports
    HP Tuner SD specialist All GM Vehicles
    2000 Mustang 438" LSx 4.70 @ 164
    NEW 346" N/A testing: 10.4 @ 132.4 N/A(875')
    NHRA Corrected: 10.21 @ 134 N/A
    Old Nitrous Best: 10.0 @ 138.89(181 DA)
    Jul 2009
    Noble, OK
    317
    post log and tune
    Are O2s responding?
    5BA8
    3,297
    Phil, are you scanning too many PIDs? Have you tried zeroing the long terms and see if the STs will move? Can you verify they're not working, or it's just a scanner issue? Example; won't hit target idle? Is it going into idle mode? Are the spark under and over tables working? Do you know how to verify that?
    PS tune and data log dammit! LOL
    email=[email protected]
    Its a 98, I'm scanning the basics. The idle is all jacked up, it feels like the STIT and LTIT are not working. It does not correct just bounces. The STIT and LTIT are all set at 0.000, the spark under and over table seem to be working. I logged another car right after it with the same setup and it worked fine. I had 2 cars on the dyno today, the 98 vette tune went fine but it just wont idle. The 2004 GTO idles perfect and dyno was a dream.
    Phil
    1999 Corvette Coupe
    5BA8
    3,297
    Quote Originally Posted by Phil99vette View Post
    They're 2 completely different PCMs. The 98 won't allow you to monitor near the amount of PIDs as the 04 GTO.
    Does it bounce just sitting there? As in no wheel speed at all?
    I would get rid of all your pids except the idle pids and see what it says.
    Still no data log?
    I'll get a data log this week. The 98s are the worst for pids and sampling rate. It doesn't bounce or anything. What would cause it to NOT go into idle mode. Could something like missfire or air pump or another sensor cause it?
    Phil
    1999 Corvette Coupe
    5BA8
    3,297
    I would think the only thing that would cause it is if it thought it was moving. Wheel speed. But if that were the case, then the idle spark tables shouldn't work either.
    Advanced Tuner printmanjackson's Avatar
    Nov 2009
    USA
    412
    they do that with clutch in too!
    '02 Corvette
    LS6, MN6, LT's/X pipe and TI's, Honker CAI, AI 243 heads, PatG Custom Cam, FAST 102, LS2 TB, Red Top inj, HPTuners & NGK/AFX
    Quote Originally Posted by printmanjackson View Post
    Phil
    1999 Corvette Coupe
    5BA8
    3,297
    Not really. It will still go into idle mode sitting still with the clutch pushed in. If you jab the throttle TF will kick in and then decay out, but it will still go into idle mode with the clutch in. Now with the clutch in and moving (wheel speed) it will not.
