Have a 99 3800 Stage II Supercharged Grand Prix. Lately I have been getting some stumbles and stutters on acceleration. I took a scan and found the scan attached, as well as P0300 and P0306 DTCs. The RPM sharply drops off while throttle position and the MAP/MAF indicate constant running. Changed the plugs, wires, and swapped coil packs to no avail. Fuel pressure is good. Even ran Seafoam thru a tank of fuel. I am starting to think it could be an injector, does not seem possible two coil packs are bad. Any idea where I should start with regard to troubleshooting further.
Attachment 31459
