now im still passing this around as an idea for a soltice im thinking about putting together as a all around multi sport(track, drag, drift) car and when i hear people talking about the compound setup i am hearing two ideas on controlling boost....someone who knows please help me out...
1st) no matter what the large turbo boosts the final boost is regulated by a bov after the high pressure turbo......so and to calculate total boost im being told 8 psi from the low psi turbo + 20 psi from the high psi is still 20 psi because its after the high psi turbo....
2nd) in order to controll boost i would need a bov for after both compressors and to get total boost calulation of 8psi low psi turbo + 20 psi high psi turbo= 28psi total into engine
which one of these is most correct...if not maybe something from each to make it correct??
i saw marks video for the strtfighter compounds and i will run dual wg like he has setup if i do this but i obviously need to know more first....and last thing how do i go about matching the turbos to eachother....(was thinking gt2871r + gtx42r or gtx45r)
