I am running in open loop (per 69tbird). I have made several 10 mi expressway runs with slow accell and decel. I then adust the VE table with using the scan data. Example: I will multiply a cell that cell which displays 5.x with a correction of .95. Did this to most cell with a > 2% variance.
However the next scan shows different cells off by 5% or more that were fine on the previous one. The cells I corrected are right on or way off too. No pattern. Am I doing something wrong? I am using the stock afr ratio error on hp tuners and my afr on logworks shows the same as hp.
