I was going to order a wideband today and I am pretty set on the Wideband Commander. Can anyone tell me how long (guess is fine) a WBo2 sensor will last? I dont see the need in getting the analog gauge if it will only be working when I have the sensor plugged in.
Also, I see that you have to calibrate the LM1 whereas the Wideband Commander you dont. Can someone elaborate as to why this is. Is one more accurate?
Has anyone had a problem getting a tach signal on their Wideband Commander?
