Results 1 to 6 of 6
Thread: NGK AFX mnitor sensor?
    Advanced Tuner =fast='s Avatar
    Jan 2009
    396
    Well guys my sensor form my wideband is out when i connect it the only thing it shows its sen1, on the instructions it says to replace sensor.
    I was looking them at the Ballenger Motorsports since i bought my wideband there and it shows 2 different ones, What are the difference?
    Bosch LSU Wideband O2 Sensor ( UEGO ) with NTK/NGK Connector for NGK Powerdex AFX
    http://www.bmotorsports.com/shop/pro...roducts_id/349
    NGK / NTK Wideband O2 Sensor ( UEGO ) for NGK Powerdex AFX, OEM replacement & other wideband systems - NGK PN 24302
    http://www.bmotorsports.com/shop/pro...roducts_id/352
    one is a bosch and one is the NTK, I like the NTK sensor better.
    however if you do some research, my 2005 honda uses the same NTK 24302 sensor, but it is available for under $100 ordered as a Bosch 15401 (NTK sensor in a bosch box)
    Ryan
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,861
    As mentioned, the Bosch P/N 15401 is the NTK sensor. You can get it at autozone.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Jan 2009
    396
    So both of them read the same air fuel or one is more accurate?
    Dec 2008
    on the Dyno
    1,825
    In my experience the NTK lasts longer than a bosch and is a little more resistant to leaded fuels.
    Located in Central Kentucky
    ShorTuning
    Advanced Tuner Screamn03's Avatar
    Feb 2004
    Vacaville, CA
    832
    If you have the AFX can you run either sensor and the controller will recognize it? In other words, if you have an AFX with Bosch sensor can you replace the Bosch sensor with the NTK one and it will work?
    -Michael Rudolph-
    2003 Redfire Cobra
    Eaton Powered to a:
    11.301 @ 129 1.68 60' MT DRs
    11.85 @ 124 1.90 60' street tires
