I am newbie to both programming and cars. I have read the car forums for a couple of years. I feel I know some about Corvettes and Camaros but not how their computers work. I have a 2004 corvette that is stock other than a Haltech Stinger R air intake. I have an LM-1 connected to my Hptuner. For the last few days I have scanned the help file a couple of times. I am going to print it out so I can read it when not engaged. I have been on LS1tech and corvetteforum tuning section. have made it through the editor, scanner and flash utilities. I chopped CAGS using 0 in the TPS spot as someone posted. It worked so I guess I manged that okay. I made my first log and the STFT were pretty much 0 or 1. My LTFT were between 13 and 10 across the board. My AFR seemed what I thought was lean to 4200 RPM's but no KR. In any case, I follow the help and for the FTC's I took and added my LT and ST's divided in half. I understood that to be a % that I wanted to change that cell by so say the two added were 10 divided by 2 gave me 5% I wanted to change. I then went to the editor, loaded my original bin file but saved it under a dated name (I have several or the orginals saved everywhere) and went to
Edit->Engine->Airflow....clicked Main VE(Primary VE vs RPM vs MAP)
When there, I picked the cells to change. Went to the "Edit multiple Values" block and clicked the "Times" button. I put 1.05 (5%) in the blank box and hit commit. When done with all the cells, I saved everything and loaded it back into the car via the flash utility. Logged another 15 minutes or so and there were changes but the numbers are very chaotic and really no better. I reset the fuel trim thing under the the VCM controls as the helpfile mentioned. Was I supposed to put "Plus" "5" for the change vs times 1.05. Is that why my changes aren't making an impact on the table. SOrry for the long post. Making sure I am changing everything correctly. Scream or Jimmy, if you get this and are willing read my first and last CVS files, that would be awesome but know you have already done this quite a bit lately and it must get old. Sorry for the long post. THanks a bunch.
Jim
