Is it safe to just download my current LS1-Edit tune and continue from there like the calibration was stock?
I've altered timing, VE, fuel, PE, etc. I seem to recall some are recommending leaving the IFR stock to accurately reflect stock injectors - and make the changes directly in Main VE.
For instance, the process of monitoring the LTFT/STFT histograms and changing the VE in the matching cell. Which values do I use in the histograms to base my alterations upon (last, min, max, avg)? If my LTFT @ 55x0.8 is +6, and the STFT is +0, then my final % learned is 6%.
So I guess my initial questions are:
1. Do I modify my IFR, leave it as is, or return it to stock (for my stock injectors)?
2. If my VE in that above cell is 45, is the calculation (45+6) or (45*1.06)?
3. What are the benefits of being able to alter the LTFT boundaries?
4. Should I disconnect the MAF to tune the VE table with my LM-1, or force closed loop and just use trims?
5. What's the easiest way to force closed loop?
6. What are the general steps to follow: i.e., tune VE via LTFT's, then tune PE via my LM-1, then achive max timing w/o KR in Main .
HPT is a lot more robust and "I don't wanna die for lack of shootin' "
