I am getting an error when trying to startup vcm editor
"component 'comdlg32.ocx' or one of its dependencies not correctly registred: a file is missing or invalid"
can anyone help?
this is v1.6
can anyone help?
this is v1.6
Ask the gurus...1.6.1 may fix this.
2002 Z51 C5 MN6 Coupe&&SuperMaxx Headers, Vararam, Ti Exhaust
Install the CD and then install the update once again.
We got this guy Not Sure, ...
1.6.1!? Where are the release notes for that version?
Jim, its a very minor upgrade... it fixes an error with the options of the VCM scanner and certain configuration files.
The cause for missing .ocx files and such is usually an upgrade has been installed onto a machine that did not originall have the CD installation that contains all of the core files.
The easy fix, install the CD first, then install the update.
I recently purchased HP Tuners and received version 1.5.2. How do I get version 1.6?
Chris
1998 Z28 Red/Gray HT, A4, 3.23
|Pacesetter, Hooker ORYP, Aerochamber|TSP Cam, PRC dual valve spring kit, LS2 timing chain|LS6 oil pump,|SLP Air Lid, P&P TB, FRA, TBB|Fuddle 3400 2.1, B&M cooler|GM iridium plugs, Taylor 8 mm|AMW catch can|J&M PHB & LCA's|HPTuners 2.1|HP House & Dyno Shop
Hi,
Log on to the customer login page and download the latest file. Your user name is the cable id and you should know your password.
Brian
