Results 1 to 2 of 2
Thread: Wiring to Hook up Wideband to Scan AFR
    Advanced Tuner Dragman's Avatar
    Mar 2004
    kentucky
    491
    Got everthing ready but what wires go were? I am using a stereo 3 way plug for LM-1 so what wires go to adaptor out of HP Tuners plug. I have a red wire and black and shield wire. Set LM-1 up for output #1 & 0 to 5 volts.
    Fastest A4 Coupe Bolt On's
    11.33 @ 119.84 mph OLSD Tune
    Tuning done by www.GearsAreUs.com
    Nov 2004
    Houston, TX
    140
    Re: Wiring to Hook up Wideband to Scan AFR
    configure outputs 1 and 2 to:
    0V = 10 AFR
    5V = 20 AFR
    that way it doesn't matter which wire you pick (red or black) it will be configured correctly.
    shield wire goes to the black (ground) on the pigtail
    red or black output goes to pin 1,2,3 or 4 on the pigtail, your choice
    make sure that if you splice to pin 2, then you insert wideband logging to the correct cell in the log table. There are diagrams in the help files!
    2002 Quicksilver Corvette Z06
    And then...
