Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Thread: A/C pressure pegged?
    glad you got it sorted! it's weird that the AC volts would work but not AC pressure becuase AC pressure is a simple table lookup form the voltage value. oh well at least you're up and running.
    I count sheep in hex...
    Advanced Tuner HawkZ28's Avatar
    Feb 2009
    Waverly, NE
    475
    Glad to hear!
    I wouldn't of even thought of the OS causing it. I never had any problems with our XPS running Vista. I have had more problems (primarily installation of HPT and the occasional write fail) with our 8 year old old Gateway running XP and my wifes's XPS running Win7.
    Hawk
    Oct 2012
    31
    Now I need to figure out how to tune the Multi VE tables since it has silly variable cams :-)
    Feb 2009
    Waverly, NE
    475
    Disable the MAF, and use the attached config. Be sure to change the cam* in the histo filters on histos 3 through 7 to match your tune.
    Also, this is for 91, for E10 or values lower than 14.6 you'll need to tweak the filters in the histos.
    Hawk
    Oct 2012
    31
    I knew there was a way using filters and cam angles, I just wasnt sure how to set up the filters and such. thanks a bunch Hawk! I did change it to use AFR Error instead of STFT since I am tuning OL for the moment
