Scanner files
Guys I just got my shipment of VCM 1.5.
Am I supposed to be able to save my scanner logs and play pack at a later time?????
If so I cant retrieve info after I save.
The Grey bar at the top of the scanner just blinks at me....
I've tried three times and the same result.. I can actually see the .cfg file and select it. but once it opens the grey bar just blinks...
Thanks in advance...
Mark
HP Tuners Owner
Re: Scanner files
after you scan, Scan->Save Data As. To playback, go to Logging->Open Log file.
Re: Scanner files
Chris,
I tried that, but in the log file its asking for a .hpl file witch it cant find
ie blank file....
Mark :huh2:
HP Tuners Owner
Re: Scanner files
when you save your scanning data, it saves in .hpl format.
Re: Scanner files
Chris,
When i go to save the scanned data file, the program automatically saves it as a .cfg file format, I try to open the scanned file later to view data and it automatically tries to find a .hpl format witch isnt there cos of the way it was saved previously....
If i tyr to open the .cfg file it loads it, but i try to play back and i get a connect error 8012..
Sorry for the head ache, but i cant even get passed step one.
Thanks Mark
HP Tuners Owner
Re: Scanner files
go to Scan -> Save Data As, it will save in .hpl format.
