wierd FTC logging quirk
notice the TPS and the cell. This entire log the FTCs arent exactly corresponding w/ the area they are being logged in. IE, FTC 22 at 25% TPS, idle at 40% tps etc. Something is up all the sudden, any ideas?
HP Tuners Owner
Re: wierd FTC logging quirk
cell 22 is used when the EVAP is closed and non-idle (this is usually the case for WOT - ie. EVAP closes at WOT). I haven't looked at the EVAP code in a lot of detail but there may be other times when it closes...?
Log your EVAP % and you should see the cell 22 corresponds to when it is closed and non-idle conditions.
Chris...
Odd, i have that system turned off and i always seen FTC 15 at wot. Ill have to check some more
thanks
dave
