Page 13 of 15 FirstFirst ... 39101112131415 LastLast
Results 241 to 260 of 299
Thread: EQ <> VE Version 4
  1. #241
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Quote Originally Posted by sssnake View Post
    While this may be true in general they are still having some issues with this capability. I am using the beta currently (latest version) and when I multiply the VVE table by 1 then attempt to generate the coefficients it crashes. This may be because my tune attempts to address MAPs greater than one atmosphere but I am not sure...
    I saw that yesterday where DSteck was having the same problem. I had the same problem with the file he posted but it worked fine on my own car, so I'm not sure what's going. Beta is beta I suppose
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  2. #242
    this will be my first time using this tool so sorry if this is a dumb question.
    I was able to import and export everything correctly and decided to use one of the sample files as its close to my cam spec. I will tune using lambda error and have my histogram set up. I was reading an older tutorial from 2012 on using the tool and tuning. I got to this point "Now, go back to VCM Editor and open the ?Engine>Airflow>General>VE Low Altd? table" but I notice my VE low ALTD table has Throttle Position (%) as the X axis, not MAP.
    I realize there are no more hooks so based on my understanding this really doesn't matter as I will make my corrections in the BC VE table by copying and pasting from the histogram and then the BC tool takes over?
  3. #243
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Don't bother. Request access to the latest beta and you can work with VVE inside avcm editor. It also uses a different algorithm which is hopefully more accurate.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  4. #244
    saw that two. I also have already paid for a COS for this vehicle so I can always do that even though I am running a 1 bar map. Would just need to reenable the maf and copy all the data.
  5. #245
    Nov 2009
    All Around
    3,149
    E38 when generating VE we select LS3 style correct?
    because if you select LS2 style the map points are different boundaries
  6. #246
    Nov 2007
    MI
    686
    I just tried using the beta to tune an 08 Grand Prix gxp. Doesn't work yet. At least for that vehicle
  7. #247
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Quote Originally Posted by GPGTP View Post
    Post in the thread about the beta exactly what it is or isn't doing and the .hpt file so they can fix it. Are you using the latest beta? They just got most of the bugs worked out a few days ago
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  8. #248
    can someone confirm this as it seems as you are asking as well.
    would that then mean that I couldn't use a LS2 sample file?
    Quote Originally Posted by SultanHassanMasTuning View Post
  9. #249
    Nov 2007
    MI
    686
    Ill have to try the car again when it comes back. The beta was a few weeks old. Everything would "work" however it wasn't doing the whole equation and fuel changes weren't taking effect
  10. #250
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Oh, yeah, VVE def wasn't finished back then. They finally "supposedly" got all of the bugs worked out now. I've only used it on one car but it worked great.
    Cool thing is it pretty much makes custom OS's obsolete for boost/SD tuning purposes. You can build a VVE "table" into boost just the same you would one that only goes to 100kpa. No custom OS needed.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  11. #251
    Nov 2007
    MI
    686
    Nice, ill let you know how it goes
  12. #252
    well while waiting for 2.25 I went ahead and messed with the BC tool. Very cool and useful tool for those not wanting to run a COS.
    I tuned the VE using LTFT and here is what my VE table looks like. I have to quit for today but will test again later.
  13. #253
    Nov 2009
    All Around
    3,149
    WE NEED CONFIRMATION which VE STYLE we should select and is it based on PCM?
    LS2 engines came both E40 and later years E38
    LS2 VE style is what all CUSTOM OS VE's look like where the Horizontal Boundaries are MAP and Vertical RPM
    on both E40 or E38
    it would be nice to know since i always like using going custom operating system for its benefits
  14. #254
    I used the LS2 and have a E38. Not sure that is right but seemed to be.
    Is there a way of changing the axis points on either BC tool or COS? I ask because on my COS my MAP plots 15,21,27,32,38,44,50,55,61,67,73,79,84,90,96,102,1 08 and BC tool goes 15,21,26,32,38,43,49,54,60,66,71,77,83,88,94,99,10 5. Or does it not matter that much off?
  15. #255
    Oct 2012
    36
    I'm having issues getting the LS2 VE table back into the bluecat tool so I can generate the VE changes to load back into HPT. Anybody have some screen shots on how to do that?
    Thanks.
  16. #256
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,772
    Quote Originally Posted by Jason Austin View Post
    Thanks.
    Explain please what you mean by "getting the LS2 VE table back in the Bluecat tool". You import the coefficients into the tool from your tune. What PCM are you using and what year?
    Ed M
    [email protected]
  17. #257
    Mar 2007
    Florida
    3,772
    Quote Originally Posted by edge04 View Post
    You can use LS2 if you want, just set up your VCM Scanner histogram to what ever X,Y axis values you want. Then copy with labels. Go to BC VE table page and at the bottom will be two input lines...RPM and MAP. Paste the labels you copied from your histogram there. They will now be the same.
    Ed M
    [email protected]
  18. #258
    Oct 2012
    36
    Thanks Ed. I've got the histogram set up and a bit of logging c/w. Now i'm trying to get those VE changes into the Bluecat tools VE so it can generate the compatible tables for me to load into HPT. I'm having some troubles with how to get the HPT (VE Low ALT) table into Bluecat.
  19. #259
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Why not just get access to the 2.25 beta that has native VVE support? It is much, much easier to use than this.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  20. #260
    Oct 2012
    36
    Got it figured out. Just had to play around with the editor to learn how to export the modded VE table into all the individual tables in the PCM.
    My histogram numbers are huge though......like in the -30s -40s and -50s. When I made the changes, my STFTs went way lean. I have to figure out what i'm doing wrong with the histogram logging for STFT-VE.
