Results 1 to 15 of 15
Thread: I can't edit.
    May 2004
    8
    I can't edit.
    It won't even open up the edit menu! It seems very incomplete? 630-531-5666. Andy
    Sep 2002
    Chicago, IL
    6,397
    Re: I can't edit.
    Did you open a file?
    What is the error message you are receiving.
    We got this guy Not Sure, ...
    May 2004
    8
    Re: I can't edit.
    I can't edit because after I read VCM it takes about 3 minutes. It asks to save file. I name file and press save. I doesn't save. I have tried several times. It seems to read fine it just won't save. I tried to save in my doc's. Computer has plenty of space. Thats why I can't edit. What should I do?
    May 2003
    Santa Clarita, Ca
    962
    Re: I can't edit.
    Are you getting an error message or it just won't save it? Don't forget you have to name the file before you save it. Something like "stock.bin"
    Ken
    May 2004
    8
    Re: I can't edit.
    I name file. But I put name after the Bin. Unless you have to put the name before the bin. ??? Also no error codes!
    Sep 2002
    Chicago, IL
    6,397
    Re: I can't edit.
    you must put the name before the .bin, examples would be:
    stock.bin
    read-6-12-11.bin
    98 Corvette Stock.bin
    May 2004
    6
    Re: I can't edit.
    It is strange that the scanner will allow the edit function to work after the key is turned off but when connected and scanner running, edit function does not work, ???
    Sep 2002
    Chicago, IL
    6,397
    Re: I can't edit.
    You cannot change the scanned parameters while you are actually scanning. To change what you are scanning, you must click the stop button first.
    May 2004
    8
    Re: I can't edit.
    Still doesn't work!
    Apr 2004
    Melbourne, Australia
    64
    Re: I can't edit.
    LASTLS1 - where in the following are you having problems?
    You run VCM Flash, read the VCM for 3 minutes, then save it to "file name".bin
    You then run VCM Editor, select File > Open, and pick "file name".bin
    You then select Edit > ... to bring up the various PCM parameters...
    Is this something simple like VCM Flash is saving the .bin file in one directory, and VCM Editor is looking at another directory? (So all you have to do is navigate the file system to the correct directory)
    If unsure, do a search on your hard drive for the file name you saved, and compare that to the directory VCM Editor is initially looking in.
    May 2004
    8
    Re: I can't edit.
    I'm saving the file in (my doc's.) After saving MANY times, after the file was named. The file doesn't show up. I just did a complete search in all files and folders. Nothing!
    Sep 2002
    Chicago, IL
    6,397
    Re: I can't edit.
    Try saving it on your desktop.
    Apr 2004
    64
    Re: I can't edit.
    What is the file name you are using?
    Sep 2002
    Chicago, IL
    6,397
    Re: I can't edit.
    When you save the file, give it a name like test.bin, then at the very top of the save as window, there should be a little section that says "Save In:" Click the down arrow to the right of the box and select desktop. Save it there.
    Then open up the VCM Editor program. Click File->Open and in the "Look In:" section, click the down arrow tot he right of the box and select desktop, You should then see test.bin
    May 2004
    8
    Re: I can't edit.
    You have to delete the * before the bin. or it will not save the info.
