Results 1 to 10 of 10
Thread: LT1 OBD2 hardware???
    Sep 2002
    Mokena, IL
    14
    I am trying to figure out what hardware was used in the 96-97 LT1 cars...Does anyone know???
    All I have found so far is the part number for a 1996 F/Y/B body PCM. It is 16214399. That is all I know. Any help would be great
    97 30th Z28 TT&&86 RX7 awaiting LT1/T56&&80 Buick LeSabre
    Re: LT1 OBD2 hardware???
    what hardware are you referring to... PCM??
    Business Network Solutions - for all your PC, network, printer and computer security needs.
    Sep 2002
    Mokena, IL
    14
    Yes, basically which processor does it use?
    Sep 2002
    Mokena, IL
    14
    Here are some pics of the internals of a 97 OBD2 LT1 PCM.
    http://lt1tech.com/pugs/OBD2/side1.jpg
    http://lt1tech.com/pugs/OBD2/side2.jpg
    Sep 2002
    19
    The processor is a MC68HC11F1 variant. Search for 16202476 on google and it will lead you to Tom Hussey's DIY post about the 97 PCM.
    HTH
    John
    I am adding a link
    http://www.diy-efi.org/gmecm/archive.../msg00279.html
    Sep 2002
    Mokena, IL
    14
    Actually found some info on this. The OBD2 and OBD1 LT1 computers are very similar. Both use Dual 68HC11's. Not sure what the F1 variant is.
    And I have no idea how the dual architecture works....
    Sep 2002
    19
    The 68hc11 is the generic chip. For different requirements of ram, EEPROM, and output type stuff there are different packages. The F1 is one of those packages. If you go to the motorola web site and search for mc68hc11f1 you can get the data sheet for that processor.
    It can best be described as two "networked" computers. Each does its own thing, has its own PROM processes independantly of the other but they share some information.
    Check out incoming there is a zip file called lt1_obd2_tside.dis. It is a very well done hack of the obd2 side of your computer. It even shows all the correct paging schemes for the 128K on a hc11.
    HTH
    John
    Sep 2002
    Mokena, IL
    14
    Quote Originally Posted by 32v_dohc
    Check where? This sounds like it could be very helpful, just not sure where you are telling me this file is
    Thanks in advance though
    Sep 2002
    19
    Dec 2002
    Yardville NJ
    40
    16214399 is for 1996
    16242921 is for 1997
    Tom Hussey also wrote the 97dmp.exe
Similar Threads
  1. 96 LT1 OBD2 Service Engine Light ???
    By aknovaman in forum GM V8 Tuning - Miscellaneous
    Last Post: 06-22-2007, 09:14 PM
  2. 97 Lt1 Obd2
    By GMRACIN in forum VCM Suite Product Info
    Last Post: 05-10-2007, 11:22 AM
  3. OBD2 LT1 stuff working with scanner....
    By Badassbird in forum GM V8 Tuning - Engine, Gas (Gen 3)
    Last Post: 12-17-2005, 12:16 PM
  4. need help decoding a sample message for lcd proj
    By okidedrak in forum OBD-I & OBD-II Hardware And Communications
    Last Post: 01-01-2004, 02:02 AM
  5. Any OBD2 LT1 Edit users out there?
    By pugs in forum Lounge
    Last Post: 09-23-2002, 04:20 PM
