I lost the histograms for many of the gen3 vehicles (STFT, LTFT, KR, O2), after updating from 2.23 beta to 2.24. I also cannot find them when going into the table to add them as data items, what gives?
Delete your .os files from your vehicles folder, this will force the scanner to repoll for the valid pids.
sounds like you aren't logging STFT & LTFT in the table display to me.
post a scanner log.
Works fine for me.
BTW any histograms based off of a application that has a vehicle that has a Main VE table won't work while connected to a vehicle that DOES NOT have a main ve table such as a 2010 Camaro, hence the reason the histograms you are trying to view don't show up as your vehicle doesn't have a main ve table.
You would need to create a custom histogram.
Final Scan Setup.hpl
Thanks Bill for all your help. After do more searching I found how to set up custom histograms, things are working great now. Not happy to see where my LTFT are but they're in the process of being corrected. I'll rejoice in the fact of connecting one dot of many in the world of tuning. Below is my set up now if you'd like to review it. Thanks once again!
