Hi, I have changed to 2 bar sd and fitted a 2 bar sensor, delphi28139776, can anyone please tell me the "map sensor linear" and "map sensor offset" values?
default is linear 200.00kpa, offset 10.33kpa
is there anything else that has to be changed also?
I ran the car and at idle it reads about 40kpa, at wide open throttle (before boost kicks in) it reads 105pka, and when boosting 8 psi as showm on autometer gauge it still reads 105kpa...
thanks in advance for any help
