Results 1 to 10 of 10
Thread: Stoich AFR?
    Stoich AFR?
    Are you guys changing the stoich afr to 14.7 under the fueling tab or leaving it 14.108? Just curious to see what everyone is doing with these.
    Oct 2007
    Crawfordville, FL
    2,412
    It should reflect the actual stoich value of the fuel being used.
    The whole table reads 14.10840 from 0% to 100%.
    Oct 2007
    Crawfordville, FL
    2,412
    If you are using pump gas with 10% ethanol, that would be correct.
    Apr 2011
    6
    question: 08 Lacrosse Super 5.3, E67 ECM I believe, I cant find a specific "Commanded A/F" table anywhere in the cal?
    I changed the one labeled Stioch from 14.67 to 14.10 but my Commanded A/F Ratio did not change, it still reads 14.7:1 ?
    using HP Tuners and scanning with Torque
    13,565
    Quote Originally Posted by JG99GSX View Post
    Look at the EQ ratio, take that and divide it by your stoich to give you a commanded afr.
    Unless that not what you are asking. Otherwise a wideband won't show you 14.1 exactly, still going to be roughly 14.7ish.
    ditch the tourqe readings for commanded a/f verify the fuel youre using actually has 10%Ethanol. Use your hptuners scanner to tell you commanded a/f hi res to see whats going on, make sure you reset your fuel trims as well and see where everything settles.
    06 Grand Prix GXP, LS4-full bolt ons, Tuned by me
    Apr 2011
    6
    How do I add the commanded a/f hi res to the scanner? thanks Jeff G
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,266
    right click-insert pid in the table(primary) display.
    Apr 2011
    6
    thnx Guys
