Page 2 of 5 FirstFirst 12345 LastLast
Results 21 to 40 of 87
Thread: Now Accepting Reads / Adding Support for many new Ford Vehicles!
    Mar 2011
    384
    have access to a 2013 5.0 flex fuel f-150 when you get that far
    My setup is a 356ci with a 260/268 (212/218 at .050 lift) duration cam with aluminium corvette heads and flat top pistons running 11.3 comp. ratio. with tuned port injection and vortec crank pick up and dizzy running a 411 pcm and 60lb bosch injectors, 1.6 ratio roller rockers. For transmission its a 4l65e built with the monster in a box mega ss kit. All in a 92 chevy ext cab 4x4 pickup with a 98 cab now installed with a third door! running only e85
    Feb 2014
    any feed back on the '05 focus 2.0 duratec with a manual?
    Oct 2007
    Crawfordville, FL
    2,417
    Did you send in a read?
    Feb 2014
    i currently have no means of powering up the ecu to do so, i have an ecu and wire harness from the focus. it is going into a custom application. The biggest feature to me is the ability to "turn off" the pats system as well as some other functions that are no longer needed for my build. the engine side of the spectrum will remain fairly stock for now. I have an ecu to donate and mail to you tho...
    Oct 2007
    Crawfordville, FL
    2,417
    Quote Originally Posted by Red_Beard View Post
    Sending PM.
  6. #26
    May 2011
    New Zealand
    34
    Eric
    Any chance on 2009/2010 Ford Focus RS 2.5 turbo
    Phil
  7. #27
    Oct 2007
    Crawfordville, FL
    2,417
    Any idea what PCM they utilize?
  8. #28
    May 2011
    New Zealand
    34
    They are a BOSCH unit, SCT currently supports them.
  9. #29
    May 2011
    New Zealand
    34
  10. #30
    I can get you a read from a 2010 Focus RS Euro spec car also!
    Just PM me if you'd like it.
    --Christian
  11. #31
    Mar 2014
    I have a Morgan Roadster 2009 which comes with a 2007 3.0L Ford V6.
    The ECU is LBO-A56 TVX0 which is the same as in the 2005 Escape.
    Will the latest software be able to read this, and if so could you easily add support?
  12. #32
    Apr 2010
    sarasota, FL
    5
    hey eric... ive got a 2010 fusion sel id LOVE to be able to tune. (hate the way the trans shifts from factory)
    i tried to read it with the 2.5 beta and i cant get it to read.
    any thoughts?
    says something along the lines of fx7 failed during active session of somthing like that...
  13. #33
    Tuner bigboykilroy's Avatar
    Apr 2007
    Aurora, Ohio
    131
    Trying to read a 2008 Ford Expedition, Having issues just syncing up. Running the latest version 2.24.578. It gets all the way to Preparing Entire VCM, then goes onto reading VCM and errors out. VCM Read Failed at loc: 0 Error: Timed OUT.
    98 TransAm WS9 Raim Air – Stage 4 4L60E Trans -3:90 Rear -1.8 HS Rockers - Full UMI Suspension – 85MM Lid – 85MM Z06 MAF - LS6 Z06 Intake - 224/230 Comp Cam - 7.350 Push Rods - 243 TEA Stage 2 LS6 Heads 61cc - Melling 10296 Oil Pump - Caddy Race Lifters - SLP Underdrive Pulley - 160 Thermo - 42# Green Top Injectors - HPT - SLP Line lock - Pacesetter LTube Headers - Yank SS4000 - 98 to 2002 PCM Swap www.mrk-motorsports.com
  14. #34
    Oct 2007
    Crawfordville, FL
    2,417
    Quote Originally Posted by bigboykilroy View Post
    Send an info log to support at hptuners dot com
    Eric Brooks
    HP Tuners, LLC
  15. #35
    Advanced Tuner Pulse_GTO's Avatar
    Apr 2008
    329
    Eric,
    Any plans to tackle the 2014 Fusion with the 1.5l? The transmission logic and torque management are horrible on this vehicle.
  16. #36
    Oct 2007
    Crawfordville, FL
    2,417
    Quote Originally Posted by Pulse_GTO View Post
    Eric,
    Possibly. Any idea what PCM they use?
  17. #37
    Advanced Tuner Ranger6202's Avatar
    Oct 2013
    Wyoming
    346
    Tried to hook into my friends 2012 Focus SE, i could scan and read parameters, but it wouldn't let me do a read entire in the editor, Kept getting an error. Am I missing something here?
  18. #38
    28,287
    Quote Originally Posted by Ranger6202 View Post
    any idea what pcm they use?
  19. #39
    Oct 2013
    Wyoming
    346
    I don't Bill, sorry. It's got that goofy auto controlled manual trans in it, And has been acting a lil goofy lately. We thought we'd hook up and see if there was anything we could adjust. Its no biggie so I wouldn't worry about pursuing support on it. Unless you guys want a file for future support.....I can dig into more?
  20. #40
    28,287
    If its a ford pcm we support(I think we support about a dozen controllers for them) I can have you read it with 2.25 but you'd likely need to go through each and every controller until you find the correct one(if you don't know what pcm it utilizes).
