I guess the main question here is , does affects tuning?
My feeling is you would be fine, as long as, you don't make any changes in the suspect areas. If you leave the data alone on that axis scaling, it shouldn't cause an issue. It's when you try to make changes to data that is incorrectly defined that you can run into trouble.
The kicker is, we all rely on the companies to be accurate in how they define things, but how do we really know? Considering how many applications they support, it must be tedious.
Jaime
I just picked up HP Tuners to use on my Corvette; do you still need any testers to help?
I own an '05 SRT4 with mods.
Is there anyway that you guys can add the compare option to the BEta software ?
I meant now
thanks. BTW is there any way to deactivate the Tip sensor correlation for calculation.
To the HP tuner team..
Is there a bit switch in this code to run 4, 6 or 8 cylinders?
When you play with these calibrations and PCM's as long as I have you find that lots of other uses can be had with specific calibrations in other applications.
Basically you could use the 4 cylinder calibration on a 8 cylinder if you had a multiple cylinder hardware switch.
When can we start logging Knock on the Srt-4 platform?
https://www.facebook.com/tuningbyshanehinds
[email protected]
2009 G8 GT [email protected] 1.60 - Sold
2008 A6 LS3 C6 Cammed [email protected] 1.44 Sold
2013 CTSV wagon 9.21@151
2015 C7Z bolt ons 10.0
Owner/Tuner Street Performance Syndicate
06 GTO: D1SC , Full Suspension, 23X .6xx lift Ed Curtis Cam, Mast Heads, Gforce 9" 4.11 Gears, Holley High Rise, Stage 12 Fuel System, Boost By Gear
01 Duramax: Blown Tranny (again) BWs467 Turbo, Head Studs, Exergy Injectors, Lift Pump, Moonshine
2014 Taurus SHO: (Wife's Car) OR DPs, Tuned, CAI
2006 TBSS; AWD SLP Catback, K&N CAI, Tuned
Can anyone confirm that we are able to tune on 07 srt4 calibers? Do they use the same computers as the neon srt4s?
Can anybody confirm if we can shut off skim on the NSRT4 platform?
I have a 2008 caliber srt
no...
