Results 1 to 8 of 8
Thread: VCM Controls
    Mar 2006
    11
    Unhappy VCM Controls
    I have MPVI Pro.
    I can not get my VCM Controls to manually turn on or off anything, MIL lite, Fans etc.
    What could be wrong?
    Thanks.
    Dec 2009
    1,084
    Have you clicked on connect?
    Mar 2006
    11
    Yes I have.
    Is there a difference between just clicking on "start scan" and connecting?
    When I click on start scan it reads all of my sensors, is that not connected?
    Thanks.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,279
    yes there is a difference.
    Mar 2006
    11
    VCM Controls
    Could the grounds on my OBD2 connector be causing me problems?
    Chasis ground verses PCM ground?
    What are the computer PCM pin-outs for a 2000 Camaro to properly hook up the OBD2 connector.
    Thanks.
    HP Tuners Support
    (foff667)
    28,279
    my advice would be to try using them on any alternately supported vehicle to see if you have the same issue, thats probably the easiest way to determine if its a vehicle specific issue or not.
    Mar 2014
    McAllen,TX
    160
    try connecting to another vehicle & see if it works that's your best option bro
    Mar 2006
    11
    VCM controls
    Quote Originally Posted by Joshtuning View Post
    Yes, it worked on another vehicle.
    It was the "nut" behind the steering wheel again.
    Thanks a lot!
