Page 2 of 14 FirstFirst 12345612 ... LastLast
Results 21 to 40 of 263
Thread: HP Tuners 2.25 BETA Release (2011+ Mustang supported + others)
    Advanced Tuner Witt's Avatar
    Pittsburgh, PA
    380
    Uploaded my stock 2014 Auto 5.0 read to the repository.
    Great support Eric, noticed however catalyst monitor and o2 response rate test parameters and stall speed under transmission parameters are missing.
    28,287
    Quote Originally Posted by S2H View Post
    looks like I can read files...but I cannot write files........
    Eric has been writing his own vehicle without issue. You might consider contacting support.
    Jun 2007
    396
    Super excited for this release! Thanks for all the hard work from Eric and the rest of the folks at HPT!
    2011 Z07 Carbon Edition
    Senior Tuner S2H's Avatar
    Apr 2005
    Schexnayder Racing - Arnaudville LA
    4,387
    yeah...eric already told me that... I know his reads and writes...
    the one I downloaded from my customer page...does not.
    -Scott -
    28,287
    You were attempting to write to a 2007 Mustang.
    The beta's intended use is for 2011+ mustang's mainly. Flashing has still yet to be enabled on older fords, gm's, etc.
  6. #26
    28,287
    New beta up that will allow you to run 2.24 & 2.25 side by side at the same time, so you can use the stable version on most applications and beta for the 2011+
  7. #27
    Dec 2009
    1,084
    I can verify that now.
    I did have to remove the Beta and reinstall 2.24 then I was able to load the Beta with out overwritting.
    Now have both Current and Beta releases working side by side.
    Good job!
  8. #28
    Bill, the new beta that allows running side by side with 2.24, was that made available to everyone who had a beta link?
  9. #29
    Dec 2009
    1,084
    Yes
    You need to update
  10. #30
    Oct 2007
    Crawfordville, FL
    2,420
    There's a party up in here today!
    Eric Brooks
    HP Tuners, LLC
  11. #31
    Oct 2007
    Crawfordville, FL
    2,420
    Quote Originally Posted by Witt View Post
    Hmm, I am pretty sure I added stall speed already. The other stuff may or may not get added. PM for details.
    Eric Brooks
    HP Tuners, LLC
  12. #32
    Oct 2007
    Crawfordville, FL
    2,420
    Update.... I did not drop the ball on this actually.
    Proof:
    That parameter does not exist in the 14 code.
    Eric Brooks
    HP Tuners, LLC
  13. #33
    Pittsburgh, PA
    380
    Quote Originally Posted by Eric@HPTuners View Post
    That would explain it then, thanks.
  14. #34
    Is anyone having problems using the compare calibrations function?
  15. #35
    Sep 2002
    Chicago, IL
    6,397
    That's still in development.
    I'll disable it in the beta until its ready.
    We got this guy Not Sure, ...
  16. #36
    Also in case anyone has a similar problem. I had a 14 mustang freak out after a completed flash and would not start/crank. I reflashed and same thing. I had to disconnect the Battery for a few min and then Reflashed again and all was well.
    Great job guys!
  17. #37
    Sep 2002
    Chicago, IL
    6,397
    Rick, if that happens again, try using VCM Scanner to clear the DTC's. We may have to incorporate that into the write process.
  18. #38
    Will try that Keith thanks. Before anyone Panics this has also happened to me using the "other" software after Writing a full tune.
  19. #39
    Jun 2010
    559
    Can i just switch users and download the 2.25 and leave the 2.24 on the first user?
  20. #40
    Sep 2002
    Chicago, IL
    6,397
    you can install both at the same time.
