Results 21 to 40 of 49
Thread: Validate Checksum Failed. You will be unable to save or flash this file.
    Advanced Tuner JETURBO's Avatar
    Feb 2013
    519
    I sent a file today to support, not sure if I clearly mentioned it was a checksum issue but iam sure you'll know it is
    Whats the turnaround on this issue
    FG F6 400+RWKW .....10.9 @ 132mph.... FIRST 10sec F6 in SA ( sold )
    DYNO DYNAMICS 1200hp ...... Tuning weapon..... ( sold )
    OFFICIAL JONNY TIG INDUSTRIES SUPPLIER ..... Biggest and lightest intercoolers for B and F falcons
    SUBARU BRZ ......AVO TURBO KIT coming......soon
    VF R8 CLUBSPORT SV...... 340FWKW.....ASE BIG SINGLE KIT .....one day
    Advanced Tuner caesar's Avatar
    May 2003
    227
    Quote Originally Posted by JETURBO View Post
    Monday is a national holiday, so you may not hear anything till Wednesday morning, Australian time. You need 2.25 access to use that file.
    May 2015
    8
    i emailed support this morning also with a validate checksum issue. I have a 2014 challenger stuck on the dyno waiting for a response.... any help ould be appreciated.
    Dec 2011
    I have the engine, transmission, pcm, tipm, skim module, cluster and ign switch from a 2006 Ram 5.7 RFE545 installed in my 1966 Belvedere. It will run and drive buut I'd like to disable some dtc's and do a little bit of tuning. When I read the pcm it comes up with this checksum error and also locks up the pcm so I have do do a battery disconnect and reset it before it will run again. I have uploaded my tune file
    Jul 2015
    i emailed support six hours ago also with a validate checksum issue.
    any help would be appreciated.
  6. #26
    HPT Employee Mark@HPTuners's Avatar
    Jun 2014
    36.1094, 115.1781
    432
    Quote Originally Posted by mobile2 View Post
    Support isn't active on the weekends, you should be hearing back from them soon.
  7. #27
    Feb 2016
    8
    Idk if I sent to correct people but having same issue on a 1998 ls1 Camaro. I posted in Tuning thread.
  8. #28
    Sent a tune yesterday afternoon. What's the timeframe on this? Just have a truck on the dyno that needs to be delivered today.
  9. #29
    Aug 2012
    17
    I need tune a dodge Ram 2011 5.7 lt with Hemi engine. I try to read with NGC4 and NGC4A and shows checksum failed. I check with other tools and shows NGC5 for this models, Hptuners support this ECM ???
  10. #30
    Jun 2014
    36.1094, 115.1781
    432
    Quote Originally Posted by cris View Post
    Read it as an NGC4A and send the file to support.
  11. #31
    Jun 2014
    36.1094, 115.1781
    432
    Quote Originally Posted by Stangguy View Post
    Time-frames can be hard to pinpoint but typically, you should receive a response within 24-48 hours or so
  12. #32
    28,287
    Quote Originally Posted by Mark@HPTuners View Post
    Save for weekends and holidays.
    ie if you email us on Friday at 6pm you likely won't recieve a response until monday-tuesday of the following week.
  13. #33
    Aug 2012
    17
    I ready did that buddy, I send two files, with NGC4 and NGC4A. thanks
  14. #34
    Mar 2016
    11
    so I have a 2016 dodge charger scat pack and im looking to do the initial read of the pcm to send in for pcm service to unlock. I did the read but it came up checksum failed. would it be saying that because the factory pcm is not unlocked? or am I doing something wrong.
    Performed read as gpec2a
  15. #35
    Jun 2014
    36.1094, 115.1781
    432
    Quote Originally Posted by TURBODAN101 View Post
    The read is likely fine, it just needs to be defined in our software. If you would like to be sure the read is okay before you send the PCM in... send the file to support. We can double check if for you.
  16. #36
    Mar 2016
    11
    cool. thanks a lot.
  17. #37
    Tuner in Training BrandonHall10's Avatar
    Tucson
    37
    Just got the "Validate Checksum Failed" with two separate PCM's using my laptop and Windows tablet. Through the OBD II port and an offboard interface.
    One PCM is stock, untouched. The other is one I've flashed over a dozen times. The only thing that has changed is, upgrading to HPT 3.0
    Emailed support with .hpt file and infolog. Waiting for reply.
    2000 Grand Prix GTP
  18. #38
    565
    Did this and got a response back saying this is not a supported vehicle. Isn't this what you do to add a vehicle to the supported list? The ecu is supported and the 2005+ versions of the vehicle are supported.
  19. #39
    28,287
    Yes, If we believe we can support a vehicle in a timely manner. If its some oddball ecm that we don't support you will receive a response that it is not supported.
  20. #40
    Tucson
    37
    I guess the thing that confuses me is, mine is definitely a supported vehicle. I get the error when reading a PCM that was previously written a dozen times using HPTuners and nothing else. I was surprised to see an error message using a familiar setup to access a licensed PCM.
