The info for the new pro interface says:
4 Analog Inputs (MPVI Pro only)
2 Switched Outputs (MPVI Pro only)
What can you do with the switched outputs?
I'm assuming you can trigger these based on some type of PID alarms...
Is black box logging required to utilize these?
Are the analog inputs differential or do they share a common ground?
Final question, how complete is the ls2 calibration mapping. Is the calibration data pretty well understood or are we in the same boat as the early days of the ls1.
