Results 21 to 40 of 47
Thread: Optimum Power Load at WOT - Coyote
    Oct 2007
    Crawfordville, FL
    2,412
    Regarding this parameter, I have not fully gone through the code to determine exactly how it is used. The reason I put it in the software is because I noticed that Roush and FRPP supercharged files have the values raised up. (Although the blown Raptor files do not).
    Eric Brooks
    HP Tuners, LLC
    Nov 2007
    232
    Good to know...for possible future reference.
    "I didn't fail, I just found 100 ways to do it wrong." - Benjamin Franklin
    Mar 2010
    Texas Hill Country
    3,299
    update?
    Dec 2005
    222
    The load at WOT table is only used in a failed MAF situation as a predictor to the expected load so that the airflow can be predicted via the speed density functions. In some of the older years, this table was used in the calculation of the scaled load (a load calculation logic available up through about MY98) if the perload variable triggered a scaled load calculation versus an actual calculated load. But in these later years it is the safety net for WOT airflow (and hence) fuel calculations under the failed MAF conditions. I normally reshape this table to reflect the expected load vs RPM curve to provide adequate protection in the event of a failed MAF. From studying different strategies and raw logic, it doesn't appear that its used in all strategies. For example in the 2011+ GT500 calibrations the table is all unity. My assumption here is that the failed MAF situation defaults directly to the SD calculation based on RPM at some other load condition, possibly at the max load seen by engine condition. I can't say for sure since I haven't seen enough of the raw logic to know for sure (another reason to be sure that the max load seen by engine properly reflects the expected max load). I hate to start rumors, but this is my understanding of the topic and I'm always open to being schooled otherwise.
    Jeff Chambers, Owner
    CRT Performance, LLC
    349 Cleveland Road
    Norwalk, OH 44857
    Ph: 419-668-4151
    Fx: 419-668-4643
    Performance Parts, Service and Dyno Tuning Specialists
    Baltimore, Md
    1,208
    Has this been proven to be true or? basically table isnt doing anything UNLESS MAF is failed in Coyote?
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
  6. #26
    Advanced Tuner bbrooks98's Avatar
    Oct 2011
    Gainesville, VA
    301
    Not to start anything thing as fact, but I could have sworn in some of my testing I couldn't keep the car in OP Mode and it'd default to lower map points giving me real low timing values when i was attempting originally to try and make it follow the load curve in boost. It wasn't till i went and lowered the values to 1.05 that it stayed consistent in OP Mode
  7. #27
    Baltimore, Md
    1,208
    I think we both know there are no facts here as of yet LOL
  8. #28
    Jan 2013
    Hawaii
    2,101
    Is this the table, the description says it doesn't have to do with load, but with aircharge and correcting the VE equations?
    Calculated load is/should be 100% at wot in all conditions boosted or NA. It is directly related to and what determines the requested torque percentage of the driver demand, and can effect PE schedualing. Current Air charge/ maximum air charge is what is used to determine this. Remember air load is cylinder airmass/ cylinder displacement airmass. The maximum air charge is subject to the ect v iat correction table.
  9. #29
    Oct 2011
    Gainesville, VA
    301
    Quote Originally Posted by murfie View Post
    is this the table, the description says it doesn't have to do with load, but with aircharge and correcting the ve equations?
    Calculated load is/should be 100% at wot in all conditions boosted or na. It is directly related to and what determines the requested torque percentage of the driver demand, and can effect pe schedualing. Current air charge/ maximum air charge is what is used to determine this. Remember air load is cylinder airmass/ cylinder displacement airmass. The maximum air charge is subject to the ect v iat correction table.
    ecm 44353
  10. #30
    Senior Tuner CCS86's Avatar
    Austin
    1,089
    I'm interested to nail down how this table is used too.
    The Roush 575 file has values pretty close to what you would expect absolute load vs RPM to look like on a PD car:
    While the FPDX0A8 strategy I am using, has values matching my stock GT:
  11. #31
    I'm curious on this as well, also using FRPP strategy
  12. #32
    Austin
    1,089
    Bump!
  13. #33
    Advanced Tuner small tuner's Avatar
    Nov 2015
    271
    dose any body figure out how to solve the issue for vct not entering OP mode with power shifting in (MT82) at high RPM. it is away for almost 1 second before it is go again OP mode when shifting . is it spark / vct op sitting issue.
  14. #34
    Oct 2016
    Poland
    1,744
    To my knowledge it only works when MAF is considered failed - when the SD takes the job it has to know what to do at WOT.
    It's not used under normal working conditions.
  15. #35
    Nov 2015
    271
    agree on that but my concern is why cam off during shifting at high rpm ?
  16. #36
    Oct 2016
    Poland
    1,744
    Quote Originally Posted by small tuner View Post
    got a log?
  17. #37
    Feb 2019
    Lewisville Texas
    38
    i thought if the vehicle never uses OP mode during WOT you wouldn't mess with it. just all the other mapped points it does use.
  18. #38
    Feb 2019
    Lewisville Texas
    38
    If it doesn't say it uses this table than you shouldn't worry about it? am i right? just making sure i haven't been doing it wrong lol
  19. #39
    Nov 2015
    271
    got a log?
    attached livelink format for 2011 mustang GT M6
  20. #40
    Oct 2016
    Poland
    1,744
    Not enough data using nGauge - need to log it with a VCM scanner.
